60K Maintenance
Old Nov 11, 2008 | 02:03 PM
TheTick's Avatar
Just did some more searching and I see that some people recommend several drain and fills and running the heat on high. I'm assuming the heater is just run between fills?
Old Nov 11, 2008 | 04:44 PM
tennsc's Avatar
Originally Posted by geesteezd
+1 on the nissan dealers..
i got mine done for 300 less than what you were quoted by infiniti
Yeah +1 on that!
Old Nov 11, 2008 | 06:49 PM
bythabay's Avatar
one drain & fill after 4yrs/60k miles is fine - no need to flush. Make sure to replace the coolant every 2yrs or 30k miles thereafter.
Old Nov 13, 2008 | 03:50 PM
KingoftheRoad1's Avatar
Originally Posted by TheTick
Does anyone know if it needs to be a coolant flush or is drain and fill ok?
The owner manual indicated just drain and fill. Make sure that you drain into a container, not just for environmental reason, so you know how much to put back into the radiator. If you use the new Preston coolant, it's probably good for the life of the car. Remember, the main reason for changing the coolant is to put the additives back into the system. As for the antifreeze protection, the old coolant does the job as the antifreeze property will not break down.
Marlin84
Apr 1, 2020 12:52 PM
f22raptor
Mar 18, 2016 08:50 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
DRG35R
Sep 16, 2015 05:33 AM
