Something new everyday
Originally Posted by g35tl600rr
03 mine does driver and passeger front. how do you do all four?
Here is the KP module for those that don't know what it is:
http://www.kptechnologies.com/
Just go to products --> window roll up
do you guys know you can turn the honk of your horn off for when you arm your car as well? you just hold your lock and unlock button down at the same time for a couple seconds and you turn it off....i'm surprised pepople are still amused by this, the salesman told me about this option when trying to sell me the car and i told him, i'm more interested in the performance of this car...lol
Originally Posted by psedog
This doesn't work on mine (pressed three then held, 4 then held, etc). I don't have one touch rear windows, so I think that is the reason why.
cool, ima go try it right now. i know you can do the fronts but not the back.
*edit* nvm, i dont have premium package. Nuts!*snaps fingers*
Originally Posted by 5150DS
I don't know about 03-04, but this does not work on all 05+ sedans. In order for all four windows to go down on 05+ you have to have the premium package. If you do not, only the front windows go down doing this same action.
I figured as much before I even tried, but I figured it couldn't hurt
If it would have worked, then I would have solenoids in the rear windows even though I don't have premium. If that would have been the case, then I was going to buy new window switches to see if I got the 1 button down feature, but alas, no solenoids.
My understanding is that there is no auto-roll-up feature (other than key in lock). This stems from safety issues. It's to prevent windows rolling up on any limbs or anything like that. By having the key in the lock it forces the person to be present and avoid just such a thing.
Design logic
*shrugs*
'06
Design logic
*shrugs*
'06
If you have an aftermarket alarm you can lower and raise the windows with a (-) output tied to the unlock and lock wires respectively. Some alarms even offer "comfort closing" which extends the lock and unlock pulse to raise and lower windows.
If you don't have an aftermarket alarm the KPtechnologies module can be installed in less then an hour - simply pull off the drivers door panal and hook up 5 wires and you're done (all windows are controlled by the wires in the drivers door).
If you like cool little features you definately need to check out the website, www.KPtechnologies.com, we have several different modules to add features that G35 should have came with from the factory.
