q45 headlight retro fit
Old May 19, 2008 | 10:56 PM
gtrefever's Avatar
anyone do this???
Old May 19, 2008 | 10:58 PM
SDGeneralCounsel's Avatar
search for KEl and project G45
Old May 19, 2008 | 11:23 PM
RST531's Avatar
are u talking about the q's gatlin gun lights?? i seen someone do it before, not sure if it was a coupe or sedan tho.
Old May 19, 2008 | 11:31 PM
gtrefever's Avatar
yeah
Old May 19, 2008 | 11:37 PM
geesteezd's Avatar
here ya go!
PROPS to jmonsale
Old May 19, 2008 | 11:41 PM
RST531's Avatar
ok ya thats it, it was a sedan. here another from his album.
Old May 19, 2008 | 11:47 PM
gtrefever's Avatar
i want to do it to my sedan but i dont know where to get them or how to do it.
Old May 20, 2008 | 12:06 AM
RST531's Avatar
heres a Z with them retrofitted.
gtrefever- here is a link to some pixs and info of them uninstalled, and prices. so you can get an idea of the price range it runs.
http://www.my350z.com/forum/showpost...84&postcount=1
Old May 20, 2008 | 12:13 AM
itgogitrev's Avatar
What's the light output like on these compared to a regular projector? I have a set of Acura TL bi-xenons that I'd like to retrofit, but I like this other option too.
Old May 20, 2008 | 06:48 PM
ttrank's Avatar
Grocery getter
I looked into these back when I did mine.
TL's are the best and a ZKW lens swap makes them even better.
Q45 are low beam only so you loose high beam. You can make the uppers your high beam but the design of the reflector is not made for this.
Old May 20, 2008 | 06:53 PM
itgogitrev's Avatar
ttrank, which projectors did you end up going with?
Old May 20, 2008 | 07:35 PM
g35freak86's Avatar
i looked into thi retrofit but found out the q45 projectors don't produce that much output. However it looks sick and like Tim (ttrank) said, you will lose your high beam. So Best option is to do a full retro fit of Acura TL projectors on top (which are high and low beams) and q45 projectors on the bottom if you want to go the q45 route.
Old May 20, 2008 | 08:14 PM
ttrank's Avatar
Grocery getter
TL with ZKW for high/low
S2000 for fogs.
ttrank's Avatar
Grocery getter
TL's are too big for the top.
The only way to get a high/low on the top is a TSX with a very difficult high/low mod.
Old May 20, 2008 | 08:46 PM
gtrefever's Avatar
how does this actually work???
