04 G35x rear diff locking?
Old Sep 5, 2008 | 12:20 PM
MidnightG35X's Avatar
Originally Posted by Qbrozen
That doesn't seem right. I mean, that means I would be in a spin before the system knows and tries to intervene?
How can the system know you're spinning before it senses that your spinning? If you can invent a traction control/stability control/AWD system that knows something is going to happen before it does (aka knows the future) you will probably become a very rich person The reaction time of the system can be on the order of milliseconds, much quicker than you can realize you are in a spin. The system uses sensors to detect spin, then tries to compensate for it before it becomes a big issue.
Old Sep 5, 2008 | 12:38 PM
Qbrozen's Avatar
What I mean is 30 mph on one wheel vs 5 mph on another wheel is a BIG difference. You are talking about one wheel spinning 5 times more than another before slippage is detected. That can't be right. I'd be shocked if it was that much.
Old Sep 5, 2008 | 12:43 PM
Well, ok, I'll give that one to you, but it was just an example to illustrate a point. The real system probably has a threshold for the speed differential between the two wheels before it kicks in.
Old Mar 1, 2012 | 06:54 AM
Carrera57's Avatar
Originally Posted by AUSS1E
OK..after pulling the awd fuse and driving for a bit it seems as though all the symptoms are gone. It no longer squeels. Sooooo.....
After reviewing the FSM it has a diagnostic series to follow. (TF-41). But I am thinking it is most likely the awd solenoid or the awd control module. Either way it sounds expensive.
let me know what you guys think....
tia
Where is the fuse you pulled and which one is it? I'm having the same type of problem but they said I need to replace the whole transfer case. So I need a quick fix until I can find a donor.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
