Arizona boys step in
What's up fellas and ladies. My 2006 g35 sedan is having issues starting up. It is like a stuttering, doesn't want to turn over. Its worse after it sits at work for 8 hours in the heat. In the am when its in the garage it still hesitates. Auto zone checked the battery and alternator and said they look fine. Any ideas? This car's warranty is 4 years 60,000 miles right? so to the dealer I go. Do any of you work at one or know someone? I appreciate it
Thanks
Ward
Thanks
Ward
For west (AZ) stuff we have our own section:
https://g35driver.com/forums/west-42/
Yes your car should still be under warranty. I would take it to the dealer and let them find the problem. The most common issues are related to the throttle body and mass airflow sensor. If you are going to look into this yourself check those.
Are you getting any check engine lights?
When this happened to me, it was the MAF sensor... it would start fine in the AM but once the car was warm, I would have to blip the throttle when i started the enigne to keep it running
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
