After Dead Battery Replaced, Car Stalls After Start, Won't Idle Unless GasPedal Tap'd
Old Oct 4, 2008 | 08:43 PM
G35 Owner's Avatar
Question After Dead Battery Replaced, Car Stalls After Start, Won't Idle Unless GasPedal Tap'd
OK, add me to the dead battery club after just under 4 yrs of ownership. Just this week my car started one time, then wouldn't again after a brief stop. No big deal - I read the large battery thread and realized that many of our batteries die early and without warning.
So I replaced the battery and the car fires right up - then dies immediately as if it doesn't hold the idle speed. I can see the tach run up, then fall to zero and car dies. If I hit the gas before the car dies, it's fine (holds idle and keeps purring along).
Any Ideas?
Old Oct 4, 2008 | 09:06 PM
Neal376's Avatar
maf sensor. make sure its plugged in (and not broken)
Old Oct 4, 2008 | 09:33 PM
G35 Owner's Avatar
Well the car runs just fine after the tap of the pedal. If it was the maf, wouldn't it have issues at any speed and throw a CEL?
Old Oct 4, 2008 | 09:54 PM
texasg's Avatar
my car has the same issue im thinking im going 2 take my battery back and get an optima red top.
Old Oct 4, 2008 | 10:03 PM
texasg's Avatar
doubt its the maf cause my car never had the isssue till the new battery got in installed
Old Oct 5, 2008 | 07:09 AM
lexusk8's Avatar
Sounds like you might have a dirty throttle body. Go to bythabay's DIY video library (there's a stickied link for that on top of the forum), and there should be a video for cleaning the throttle body. That should help get your idle speed back to normal.
Old Oct 5, 2008 | 01:42 PM
Neal376's Avatar
no. nearly all vehicles, if you unplug the maf, you cant idle.
same with vacuum lines. check for those too
Old Oct 5, 2008 | 03:06 PM
deuce818's Avatar
i have the same problem -_-
Old Oct 5, 2008 | 03:28 PM
fiveightandten's Avatar
Any Ideas?
It probably runs like hell right now too...uses up more gas than it should, maybe expels visible emissions out the tail pipe...something like that?
The battery died, so the ECU got reset. The car probably just needs to be run for a while. There are drive cycles that you can go through to get it through its OBDII tests sooner rather than later. But my guess is that after an amount of cold starts, highway driving, city driving, idling at lights, ect. it will be just fine. I'm no Nissan expert (ok, I know nothing about Nissans), but this happened to my M3, and I was told it can take up to 2 weeks for the computer to completely relearn all its fuel maps and go through all the motions. My local emissions testing facility confirmed that this isn't an outlandish amount of time.
Drive the car for a while and see if it gets better. FWIW, drive cycles usually involve idling the car for a few minutes, then driving at a steady 20-40MPH for a while, then at a steady highway speed for a while, then idling...but maybe not in that order. In any case, try not to go through any large fluctuations in the throttle, as that can reset the drive cycle sequence.
Hope that helps.
-Nick
Old Oct 5, 2008 | 08:11 PM
Neal376's Avatar
please check your maf and please check for vacuum leaks and then come back. This isnt a complicated mater
Old Oct 5, 2008 | 09:16 PM
Sponger's Avatar
6MT Brembo Coupe
Man, there is so much bad info on this forum.
Old Oct 10, 2008 | 10:59 AM
G35 Owner's Avatar
Care to elaborate?
Old Oct 14, 2008 | 10:43 AM
texasg's Avatar
car is back to normal after a bout 2 weeks after the car cranks it stays on.
Old Oct 14, 2008 | 10:58 AM
iggs's Avatar
You never had a problem to begin with. "idle learn procedure" should be performed every time ECU is reset as outlined in Nissan/Infiniti manual. Takes about 20 minutes.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
ghost_g35
Aug 7, 2015 10:31 AM
realtalk21
Jul 20, 2015 09:07 AM
