Fuel Damper Replacement - TSBITB06-012
Old Oct 10, 2008 | 01:38 PM
mustangg35's Avatar
Has anyone performed this TSB, i.e. replaced the fuel damper? I am curious as to how difficult it is. Mine is definately making a rather loud thumping noise in the passenger side (as described in the TSB). I have heard dealerships want several hundred $$ for this. The damper itself is <$100.
Old Oct 12, 2008 | 12:16 PM
Noremac's Avatar
I'm not familiar with this problem, but from reading the TSB, it doesn't seem that difficult. Have you done the diagnosis in the TSB?
Old Oct 14, 2008 | 11:03 AM
mustangg35's Avatar
I did do the diagnosis. Basically you grab the fuel damper line and see if it makes the same "thump-thump" as is heard in the passenger seat. It does.
The one thing that had me concerned is the use of a special tool to separate the fuel damper line from the under car line.
Old Oct 15, 2008 | 11:07 AM
CLyons0203's Avatar
i will like to see a pdf of this TSB
Old Oct 15, 2008 | 03:23 PM
sloppymax's Avatar
go to infinitihelp.com and sign up. they allow either 1 or 2 pdf downloads of the tsbs per day unless you you pay for a membership.
jsimonk
Dec 22, 2023 03:49 PM
reavensf
Sep 17, 2015 11:30 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
brian_z
Jul 22, 2015 09:19 PM
