How do i change my Fog Light Bulbs?
Old Oct 30, 2008 | 12:39 AM
RNAG35's Avatar
Exclamation How do i change my Fog Light Bulbs?
I want to chang my fog light bulbs to yellow but i dont kno how i got a 06 g35 sedan. thank you!
Old Oct 30, 2008 | 03:09 AM
kailep's Avatar
You need to peel off the wheel well liner by removing several clips. It's easier if you take the wheel off so you have more space. It's very simple. Took me no more than 10 min on the first one and less than 5 min. on the second one.
Do you search. There should be a DIY instruction in that section.
Old Oct 30, 2008 | 12:05 PM
lexusk8's Avatar
^ And just to add on to what he said, the fog light bulb is held on by a metal retainer clip. You would have to apply pressure on the clip to release pressure on the bulb, and then you can remove the bulb itself. Memorize the orientation in which the bulb is removed so that when you install the new bulb, the orientation will be the same way. Hope this helps.
Old Oct 31, 2008 | 06:17 PM
RNAG35's Avatar
thanks this helps a lot
Old Nov 1, 2008 | 07:37 AM
jimmyc13's Avatar
Are you being sarcastic or did that help? I have some step by step instructions on here to get to that area....https://g35driver.com/forums/g35-sed...ight-bulb.html
Ignore the process for changing the clearance bulb though, as I don't think the '06's have one...
Good luck!
Old Nov 1, 2008 | 07:46 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
look in the DIY section, i have one posted in there.
-GP-
Old Nov 2, 2008 | 04:00 AM
ttrank's Avatar
Grocery getter
My guess is you purchased it.
Old Nov 2, 2008 | 04:35 AM
NathanJax's Avatar
..... I WIN .....
punctuation and spelling FTW
Old Nov 2, 2008 | 10:32 AM
Wannabe6MT's Avatar
-MN G Crew-
^rofl nice catch! I didnt notice it at first.
What size bulbs are the fogs? Im going to do them as well on my car.
Old Nov 2, 2008 | 01:32 PM
NathanJax's Avatar
..... I WIN .....
9003
http://www.sylvania.com/ConsumerProd...lacementGuide/
Old Nov 2, 2008 | 01:49 PM
skull_leader's Avatar
bulbs
i'm confused on the size? i thought the foglights were h4... on the lighting forum it said 9001... now 9006? im planning on piaa 2500ks but the h4 cost more but the 9005/9006 is about 20$ less... what size do i get
h4
9005
9006
9001...
i have an 05 sedan
Old Nov 2, 2008 | 06:59 PM
Wannabe6MT's Avatar
-MN G Crew-
Which bulbs are you guys recommending then for the lower fogs? What are some people using? I want to order some this week..
Old Nov 3, 2008 | 10:35 AM
blklude98's Avatar
+1
Also, i'm wondering how the highbeam would be with a yellow bulb...would it be harder to see?
http://www.xtremewhite.com/ORD-Light...80-1-1-1-1.cfm
I was thinking of getting this one and hoping that the clear part of the bulb was for the high beam.
Any input?
Old Nov 3, 2008 | 01:05 PM
jimmyc13's Avatar
Originally Posted by blklude98
+1
Any input?
What does it mean by "yellow top clear bulb"? What color light will it emit, it doesn't say.
I have a yellow fog bulb in my car (PIAA) which then produces a yellow high beam. It's really freaking bright & I don't have any issues with it...though I never really drive w/ my high beams on.
Old Nov 3, 2008 | 11:26 PM
jimmyc13
wassup jimmy just wondering what size did you use for your pias.... im plannig on using piaa 2500k but dont know what size... also any pics of your foglights day/night... and how do you like them
