springs on sport suspension
Old Oct 30, 2008 | 11:56 PM
bama g35's Avatar
i have a 2003 g35 with the sport suspension,i`m looking to lowering it. What springs would you guys recommend for a flush look and pretty good ride. Also i will be on 19 in. m45 wheels.Plus i did the search thing too.
Old Oct 31, 2008 | 01:46 AM
GooberGman's Avatar
I'm on OEM tokico sport shocks and revised(05) Z springs for a 1" drop all around and LOVE the ride & handling.
Old Oct 31, 2008 | 05:23 AM
Hotdawwgman's Avatar
S-techs are good too!!!
I am on H-tech and i love the softer ride. the spring rates of the H-techs are softer than the spring rates of the Nissan sport springs that come stock on the G... So for the same or better get the S-techs!
Old Oct 31, 2008 | 11:52 AM
G35Papa's Avatar
+1 on S-techs
Old Oct 31, 2008 | 03:17 PM
bama g35's Avatar
would i have to roll my fenders?
Old Nov 1, 2008 | 10:02 PM
ihaveamustang's Avatar
balla on a budget says unrevised (04/04) z springs. They have the same spring rate that's on your car now- just a little shorter. Not sure if you would rub w/ 19s though. I'm going to start researching that for when I switch to the coupe 19s. Good luck.
Old Nov 1, 2008 | 10:09 PM
NAT@FFTec's Avatar
my sedan is dropped on tanabe df210 coupe springs. Its about a 2" drop for the sedan.
heres some pics to give you an idea of how much it drops
Old Nov 2, 2008 | 03:54 AM
ttrank's Avatar
Grocery getter
If you did the search, you must have read the FAQ?...
Old Nov 2, 2008 | 04:32 AM
NathanJax's Avatar
..... I WIN .....
There's a sedan FAQ thread?
J/K
Old Nov 3, 2008 | 12:39 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
front z springs and rear non-sport cpe springs...1" drop front and .5" drop rear. It is even, handles great, and has a good ride...even on 19s and 35 series tires.
Old Nov 3, 2008 | 03:46 PM
FenixL1P's Avatar
see my sig..
AARONHL's Avatar
Whats the spring rate (progressive?)? And what shock are you using?
Old Nov 3, 2008 | 03:58 PM
AARONHL's Avatar
Hotchkis 350z springs with red OEM Tokico shocks, about a 1.75" - 2" lower than stock.
Old Nov 3, 2008 | 11:13 PM
SoCalTed's Avatar
just save a few extra bucks and go with coilovers. You will be much happier. I started with Eibach pros, then sportlines and currently have Tein Flex. I shoulda just done it in the beginning. You can go with Tein Basics for about $750 to $800.
Old Nov 3, 2008 | 11:27 PM
NAT@FFTec's Avatar
according to tanabes website, they list the spring rates at 5.5FR / 6.3RR. cant give you an exact lb the spring rates are rated at.
i am on the oem sport struts
