another offset question
Old Nov 8, 2008 | 03:34 AM
koG35ko's Avatar
Question another offset question
Hi Guys,
got some offset questions. hope some of you can help me.
been doing lots of researching and reading on previous threads, but still a little confused.
I am looking to purchase staggered 19' wheels for my 2006 G35 sedan.
choosing between: Axis Shine 19's, ADR M-Classic 19', or Stern ST-2 19'.
all 8.5 front, and 9.5 rear.
i read on previous FAQ post on here that the front can fit 8.5" +35-40mm
and rear size can be up to a 9.5" +45mm before modification is required.
i really like ADR M-Classic, but the front offset is +32.
from what i understand. this will cause the tire stick out and rub.
is this correct?
For Stern ST-2, front offset is only +20. is it even possible for me to put these on??
Of the 3, Axis Shine is the best fitting by looking at the specs. 35+ in front.
and to be honest, this is the CLEANEST looking of the 3. (3 inch lip on the back!!)
would appreciate any input or suggestions, thanks!
Old Nov 8, 2008 | 12:54 PM
ttrank's Avatar
Grocery getter
+32 will fit on the front but may rub a little depending on how low you are and what size tires you have.
Old Nov 8, 2008 | 06:37 PM
GooberGman's Avatar
Depending on your rear tire size your 9.5 rear can go down to a +38 or 40 before you need a roll. I'm currently running a 40 with a 265 and no problems and some even go 10 +40 with - camber.
Old Nov 9, 2008 | 12:36 AM
dmitriylm's Avatar
Originally Posted by koG35ko
Hi Guys,
is this correct?
Hope you get some ridiculous lift kit to go along with those nineteen foot wheels.
Old Nov 10, 2008 | 12:55 PM
Tunerz_Store's Avatar
You will be fine up front with a 32. I have 35 on 8.5" wheels up front and thought about adding a 5mm spacer. My tire size is 245/40, with the spacer I may try to fit a 255/40. I may consider a 5mm spacer for the rear on the 9.5's to bring them out to 40. Running 275's back there.
Old Nov 13, 2008 | 10:44 AM
lightspeed1's Avatar
Hey I also have a quick question. Some one is seeling me 2007 G35 stock wheels. They are 18 X 8.5 with a 50mm offset (all 4 of them). I want to put these on a 2004 G35X, will these fit with out any extra modifications or will need to make mods?
Old Nov 13, 2008 | 12:39 PM
I would run a 15mm spacer just so they aren't so tucked.
Old Nov 13, 2008 | 03:06 PM
the hell with it then. I am not buying them. Dont want to add to my frustration by needing a spacer. i will look for the same wheels but instead get the 18 x 7.5 ones, which have a 45mm offset if i am not mistaken. This should be a plug and play. What tire size and brand would you recommend? Winter and summer, if possible)
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
