bulbs.. a few questions
Old May 31, 2004 | 12:32 PM
G35abadiguard's Avatar
I am interested in changing
License Plate Lamp - Bulb 194
Corners - Bulb 194
Under Front Doors- ?
Rear reading lamps- ?
Front reading lamps- ?
Can someone please fill in those bulb sizes for those 3...
The thing is i found this website http://autolumination.com/festoon.htm and if you scroll
down a bit you will find 31 mm , 36mm , 39 mm size bulbs.. can someone please tell me which ones i need for the lamps..
Another question.. Can someone explain to me how to pull out the front reading lamps (where the sunglass holder) is.. i tried with a screw drive to pull it down and it looks liek im screwing up the plastic so i stopped.. i would like to make those bulbs xenon white. . last question.. is there any way i could change the front mirrors lights? It seems liek there LED or sumtin i dunoo. can someone try to explain how to change that ifyou can??
Thanks in advanced n sorry for all these questions. i just would like to learn more about my car..
Pictures...
Old May 31, 2004 | 03:07 PM
Re: bulbs.. a few questions
sorry i put the wrong link ...here..
http://superlumination.com/festoon.htm
Pictures...
Old Jun 2, 2004 | 04:46 AM
skeleton_cru's Avatar
Sedan
abad,
To remove the front or rear map lights or reading lamps you need a small straight slot screw driver and a paper towel or thin rag used as a buffer so as not to wreck the plastic. The pry points should be illustrated in your owner's manual. As for the bulbs...it's an 8 watt T6 bulb (front and back). Under the doors is a 5 watt bulb but I don't know the type.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
