Going nuts trying to find a bulb!
So I've searched for a bulb guide and haven't found anything specific to sedans that will answer my question. One of the bulbs mounted inside my low beam reflector is out. I'm assuming this is a DRL bulb? It's not the actual HID bulb, but a bulb that is mounted on the side of the reflector and is lit when the light stalk is moved one click. I'm going in for an oil change tomorrow and would like to stop by Kragen and pick up a bulb so they can change it at the same time. Feel free to correct me if this is in the FAQ or something of the sort.
Here are some pics to help access/replace the clearance bulb (also known as the city light in the pics):
When you find the bulb socket for the city light, grab and twist CW or CCW (I can't remember but try both) until the socket feels loose, then pull out with the bulb. Pretty simple.
Originally Posted by dmitriylm
Replacing this bulb is the same as all others right? Remove wheel, pull back fender lining, replace bulb.
Anyone know of any good LED replacements over the halogen? I read a few threads about the coupes and certain LED solutions will not fit into the socket even though they match the 194/168 base. Is this true of the sedans?
nah they fit. just make sure it's 194/168 and you'll be fine. Check out http://www.v-leds.com/Shop/Control/fp/SFV/32481. They got tons of choices
Originally Posted by gtbigup01
hile you're out bulb shopping you might as well purchase one that compliments your HID instead of the yellow stock look unless you like it like that. PIAA offers one and i am sure other manufacturers offers this type also. You might want to try to get one in super white or similar
Originally Posted by Mustang5L5
What size bulb is the fog light/high beam bulb?
9003
http://www.sylvania.com/ConsumerProd...lacementGuide/
