noobie, oil change question....
Old Dec 8, 2008 | 12:54 AM
Cali_G35's Avatar
hey guys, i just purchased 06 g35 sedan and i can't tell if my g35 has synthetic oil vs. conventional? Is there way to find out?
Old Dec 8, 2008 | 12:58 AM
Hotdawwgman's Avatar
my best answer would be to just change the oil and use the preference that you want... I use using full synthetic and i am loving it!
By the way, welcome to driver and if you have anymore questions, feel free to ask...
Old Dec 8, 2008 | 01:06 AM
Cali_G35's Avatar
how much is full synthetic oil change.. i was quoted $65.00 @ EZ lube.
Old Dec 8, 2008 | 01:10 AM
gary c's Avatar
Welcome to Driver....!
There's no way unless you took a sample to a chemist. However now would
be a perfect time to make sure your new car is getting the best oil possible.
Costco sells Mobil 1 with filter for $24.99, that's a great deal take advantage
of it. Or Wall Mart sells Mobil 1 for a good price just not as good as Costco.
Gary
Old Dec 8, 2008 | 01:12 AM
Cali_G35's Avatar
how hard is it to oil change our g35?
Old Dec 8, 2008 | 03:54 AM
Easy... i change my own oil... i use Motul...
Old Dec 8, 2008 | 04:21 AM
Cali_G35's Avatar
I am not mechanically incline, so what kind of tools do i need? is there DIY?
Old Dec 8, 2008 | 06:23 AM
BuckeyeG's Avatar
the DIY thread is a great thread to look at its near the top of the sedan forum.
https://g35driver.com/forums/g35-sed...eo-series.html
oil change
http://www.infinitihelp.com/diy/gsed...ment_video.htm
Old Dec 8, 2008 | 08:10 AM
Mustang5L5's Avatar
Anyone know what size the nut is on the drain pan?
Also, does this 3.5L use the same TINY oil filter as an '05 Maxima? I've done a change on that car before, just wondering if it's the same.
I haven't done an oil change on my G yet since i got it, so just trying to prepare. I'm one of those people that changes my own oil even if it's 10 degrees outside.
Old Dec 8, 2008 | 08:33 AM
6MTFTW's Avatar
IIRC, 14mm. And, the filter is pretty small.
Old Dec 8, 2008 | 09:02 AM
lexusk8's Avatar
Yeah the oil filter is pretty much right there next to the oil drain pan, you can't miss it. There's enough space there to use a filter wrench to remove the filter. Glad to hear you're willing to brave the elements of Mother Nature to get an oil change done
Old Dec 8, 2008 | 09:33 AM
Yv12345vY's Avatar
You can use the tiny filter, Mobil 1 MI-108, or go for a bigger one, Mobil 1 MI-110.
Old Dec 8, 2008 | 05:56 PM
Braintree's Avatar
While it's relatively easy to do, I'd get a buddy to assist, especially one that knows a bit about oil changes. The DIY's here are excellent.... but, one mishap and you could have a real mess on your hands (i.e, oil everywhere--- ever try to clean up an oil spill???). Good luck and welcome to the Forum!
Old Dec 8, 2008 | 06:00 PM
Swivel's Avatar
Moderator
SMALLER, I was shocked. But seems to work perfectly well. I'm going with the Maxima-sized Amsoil filter next change.
OP, it's an easy job even if you're not very mechanically inclined and you'll be satisfied in the end that it's been done right.
Old Dec 8, 2008 | 06:01 PM
Yv12345vY's Avatar
For a DIY get a Fumotovalve as well. It'll make the whole process a ton cleaner and easier!
