headlights removing
headlights removing
i know u have to have the bumper/grill off and its all those (10mms?) bolts around the headlight but when everythings unbolted do the headlights lift up and out or do they come forward(pull towards front of car?)thanks!
You just need to "drop" the front bumper forward, not completely remove it
https://g35driver.com/forums/faq-diy...ple-steps.html
After you remove all the bolts holding the headlight in place, the harness plug is attached to the back of the headlight, you can take a long flat head screwdriver and place it on the backside of the plug, twist and it will slide off. This makes it a whole lot easier to unplug the headlight from the harness.
Good luck
Good luck
I'll take what I can get.
Good luck
Good luck
^No! haha
I still haven't even done mine yet and to be honest, I think I'm not going to anymore..I'm just going to redo another set of lights I have and do the clear turn signal again and call it a day. I'm trying to finish this car once and for all!
^No! haha
^That was a secret! lol......and that would be me getting away from not having to do the work myself
Hey...if the price is right....can you blame me for not wanting to pass up a good deal?
^No! haha
Then we send them to ttrank for projector retro - right Tim?
You know those black clips that are in the fenderwall, those black push clips, I can't seem to find it, I don't think I have it. I'm having a hard time pulling the fenderwall back to disconnect the side marker harness as described in the instruction
