do you guys keep your spare tire?
Old Dec 20, 2008 | 10:40 AM
erklep's Avatar
Originally Posted by Mustang5L5
I've had TWO situations where my tire went flat on the highway and it was not safe to pull over or stop where I was. So i had to drive until i could safely stop and pull over.
The tire was unrepairable and i had to put the spare on and go buy a new tire.
My only two flats...destroyed my tires just by trying to get off the side of the highway safely. One particular time was on a bridge with no breakdown lane.
hazards and low speed will usually save the tire. it might break the sidewall but it will usually buy you enough time till you get home to have a new one put on.
Old Dec 20, 2008 | 10:45 AM
PAIXAO's Avatar
I keep mine in both of my cars. I've never had to use them, but you never know. Sure, it weighs more but it's only about 30lbs and I'd rather haul around 30lbs of reassurance then be left screwed with a flat when I'm pressed for time.
Old Dec 20, 2008 | 11:46 AM
OCG35's Avatar
for daily driving (even spirited) the spare tire isn’t going to make a difference by removing. I keep mine in - I have a donut though - absolutely no reason for full size spare (for me), since I would never drive far on a spare anyway.
When I go to the track, I usually take it out (sometimes not) and take 2 cans of fix-a-flat, just in case.
BTW, full size or not, check the tire pressure regularly! I recently checked mine and it was 20psi (supposed to be 60psi) - I dont think I had ever checked it prior (4 years) - maybe once... it would have done me no good if I needed it - now I'll check it quarterly at least (I dont drive it much).
The primary reason I run with it isn’t even for an emergency though... without it, the trunk floor has a big dip (even with the particle board cover thing) - so I use it basically for stability of the trunk floor.
Old Dec 20, 2008 | 11:50 AM
Braintree's Avatar
I put an oval shaped, tin container in the tire's place. I keep tools and stuff in it. But more importantly, it is the same dimension as the spare, so there is no dip or hollowed out area in the trunk and it fully supports the cardboard overlay.
Is it really supposed to be 60PSI??
Old Dec 20, 2008 | 12:41 PM
mIKE's Avatar
yes on 60 psi
Old Dec 20, 2008 | 01:26 PM
MALIBLOC's Avatar
sold my set for 500.00, if I need a spare I'll just buy it
Old Dec 20, 2008 | 02:35 PM
OCG35's Avatar
60psi for donut... full size 35-40
Old Dec 20, 2008 | 02:41 PM
Mustang5L5's Avatar
Def check the tire pressure. I discovered my full size had a nail in it and was down to 5psi
Old Dec 20, 2008 | 10:10 PM
ttrank's Avatar
Grocery getter
I have a fuel evap box, fuel surge tank and Bosch race pump in the spare tire well...
Old Dec 20, 2008 | 10:23 PM
OCG35's Avatar
You don’t count. You probably have a button that vaporizes the flat tire and auto-mounts a new full size while traveling 150mph.
This thread is for mortals. You must leave now.
Old Dec 21, 2008 | 03:26 AM
Tollboothwilley's Avatar
+1
LOL
Tim obviously runs with a spare...
Old Dec 21, 2008 | 06:28 PM
ttrank's Avatar
Grocery getter
LOL
No spare here. I did have an OEM coupe 19 for a spare but now with the new fuel system it won't fit.
Old Dec 21, 2008 | 06:47 PM
Beebo's Avatar
i keep mine all the time i only take it out if i go to the drags. (like it does any good haha)
Old Dec 21, 2008 | 08:57 PM
TOPNOTCHSEDAN's Avatar
I got rid of mine cus its too much weight, i have my amp in there, & jumper cables just in case...
Old Dec 21, 2008 | 09:19 PM
  #30
Mustang5L5's Avatar
The weight does come in handy when driving in the snow
