Aiming 2004 Reflector Headlights
Old Dec 24, 2008 | 02:50 PM
jmueller's Avatar
Exclamation Aiming 2004 Reflector Headlights
Just got the car and did a bunch of work on it including the differential fluid change and i feel as if i need to give back to the fourm esp at this time of year.
I found no where on here explaining how to adjust the reflector headlights so here it is
Using an 8mm wrench to adjust a white **** that looks like a gear on the other side.
To move the driver side headlight beam up rotate the white **** down!
obviously rotate the **** up to make the beam shine down
To move the Passanger side headlight beam up rotate the white **** up
These directions are to be used as if you were standing over your engine bay and moving the wrench in the tiny hole that nissan gives you to access the white ****.
Good luck!!
My headlights were aimed absolutly to close to the car and visibility was almost nil past 20 feet even with fog lights on.
Old Dec 24, 2008 | 03:05 PM
Mustang5L5's Avatar
Is there a way to aim the HID's?? Mine also point to the ground too close in front of the car it seems.
Old Dec 24, 2008 | 04:54 PM
jmueller's Avatar
thats what im talking about..... if u have projectors, search for that
Old Dec 24, 2008 | 06:32 PM
AceG35X's Avatar
+1 thanks for the info
Old Dec 26, 2008 | 04:52 PM
nephewg35's Avatar
can you please post up some pictures, I'm not able to locate the white **** that looks like a gear on the other side that you're referring to. thanks
TNRocker
Sep 21, 2015 08:36 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
twentyeggs
Sep 11, 2015 03:58 PM
gatorglaze
Sep 10, 2015 12:03 PM
