Intake and Exhaust
Old Mar 26, 2003 | 03:43 PM
ijk's Avatar
ijk
Re: Intake and Exhaust
than what good is intake or exhaust when it doesn't help the car???.....
just better sound??
Old Mar 26, 2003 | 04:40 PM
ryoken's Avatar
It does boost power in the upper rpm range. It'll give you a slightly better quarter mile time.
Intake and exhaust do a lot more for a car with other mods as well, such as forced induction.
Old Mar 26, 2003 | 09:55 PM
ijk's Avatar
ijk
how does it improve the quarter mile when the torque goes down???
Old Mar 26, 2003 | 11:07 PM
ryoken's Avatar
Because the power goes down at low rpms, and up at higher rpms. In a 1/4-mile run, you're only at the low rpm points when you first launch in first, then you tend to keep the car in it's powerband (where the exhaust increases the power) because you're running full-throttle the whole way.
In normal city driving, you don't run full-throttle, so the car tends to run around in those lower rpm ranges.
Basically, you're improving your ability to race, but reducing the daily driveability of the car. Though, on a big V6 like we have, the drop at low rpm shouldn't be that much. It has more of a negative effect on small 4-cylinder engines.
pestilence's Avatar
I think the torque is only low in the under 4k rpm range.. and after that there is an increse..
..pestilence..
Old Mar 26, 2003 | 11:45 PM
ijk's Avatar
ijk
ah....
wats up with the post about rain and CAI??...is it that dangerous to drive in the RAIN?? It rains alot here in florida so i am worried.......how is it not dangerous for stock intake then???...
(p.s)thnx to all those guys that is helping out this NooB
Old Mar 27, 2003 | 12:09 AM
ryoken's Avatar
CAI's usually reroute the intake to suck in air from the fenderwell or some other low, exposed location. The stock intake is higher, behind the grill and under the hood.
Old Mar 27, 2003 | 05:07 PM
ijk's Avatar
ijk
then......wat do you think about Injen CAI with HKS or Greddy exhaust???
if i do change these parts...does it void the warranty???
Old Mar 27, 2003 | 05:13 PM
ryoken's Avatar
Personally, I'm not going to mod my car for awhile. I wouldn't put a new intake or exhaust on my car unless they were going on there to help a turbocharger or supercharger. But that's just me.
An intake and exhaust won't void your warranty. If you do have problems, the manufacturer would have to prove that the aftermarket parts caused the problem. Intakes and exhausts don't generally cause problems. Incorrectly installed turbos are a whole other matter. [img]/w3timages/icons/smile.gif[/img]
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
