new jdm "bump" clear corners review?
Apr 6, 2009 | 07:29 PM
  #31
Chris, post pics. i want to see what yours look like with the LEDs.
Reply 0
Apr 7, 2009 | 01:03 AM
  #32
Ok Janik, I'll snap some pics tomorrow. They're just a replacement LED for the OEM bulb...clear bulb that burns an amber light when on.
Reply 0
Apr 7, 2009 | 02:00 AM
  #33
I've had the flat clear corners for about 2 years and bout a month ago switched to the newer bump ones. They look ok - not worth the $40 - spend it on something else man!
Reply 0
Apr 7, 2009 | 08:55 AM
  #34
I got the Amber BUMP corner from riverside.
It's a nice touch that only other G35 drivers MIGHT notice...especially in Amber
Reply 0
Apr 7, 2009 | 01:16 PM
  #35
Quote: Ok Janik, I'll snap some pics tomorrow. They're just a replacement LED for the OEM bulb...clear bulb that burns an amber light when on.
what part #? And will it fit the flat lense?...
Reply 0
Apr 7, 2009 | 01:19 PM
  #36
Quote: what part #? And will it fit the flat lense?...
most of these will fit the regular clear corners. the ones that wont fit should be obvious.
http://www.v-leds.com/194-168-158-LE...orLanding/true
Reply 0
Apr 7, 2009 | 01:28 PM
  #37
^^^ I've seen all those - several dont fit. Thanks though.
Reply 0
Apr 7, 2009 | 01:30 PM
  #38
These are the ones I got Mike. I have extra...PM me your address and I'll send you a set.
http://www.v-leds.com/Exterior-LED/C...81075-1-2.html
Reply 0
Apr 7, 2009 | 03:18 PM
  #39
Quote: ^^^ I've seen all those - several dont fit. Thanks though.
Which ones don't fit? I'm getting clear corners in a month or so, and I was looking at getting one of these as well. I don't want to get a non-fitter.
Reply 0
Apr 7, 2009 | 04:54 PM
  #40
Quote: Which ones don't fit? I'm getting clear corners in a month or so, and I was looking at getting one of these as well. I don't want to get a non-fitter.
typically the ones with many leds aren’t going to fit... also, the one that they call 180 degree directional (I don’t know that part number and am too lazy to go to the site to look it up) - it does not spread the light the way they make it seem...
Just get the ones Papa said he's using since apparently he is using those and they work.
Reply 0
Apr 8, 2009 | 01:56 AM
  #41
^I double checked, they clear the standard corner lights as well.
Some pics
Reply 0
Apr 8, 2009 | 03:02 AM
  #42
^ now make 'em blink chris... that's what the bump is for.
Reply 0
Apr 8, 2009 | 04:22 PM
  #43
My corners have been blinking since 2003
One of my first mods
Reply 0
Apr 8, 2009 | 04:45 PM
  #44
they blink with the leds?... Mine blink with the incandescent, but not led... did you have to wire in a resistor?
Thanks for the offer to send the bulbs - I'll PM address to you... I have several sets of different leds (red, amber), I'll look up the part numbers so you can see if you can use any of them for anything... speaking of leds, I'm still waiting for engine bay parts to be finished (plating) so I haven’t even wired up the engine bay lights yet (in case you were still wondering)
Reply 0
Apr 8, 2009 | 04:49 PM
  #45
No extra wiring done. Just replaced OEM for these and they still blink. They already have built in resistors. PM me....ill send you some.
Yeah....the engine bay lights...I thought you'd have it done by now. I added in an extra light I need to take some better pictures but not till I'm done with a few more things.
Hurry up!
Reply 0
