Keeping Fogs ONLY on? Module ever made?
Old Feb 6, 2009 | 12:21 AM
Idyfohu's Avatar
I remember reading about a module in the works to keep fogs on only...since we can only have them on if the headlights are on stock. Not to mention, our backwards setup, with lights, then parking lights.
I'm thinking about doing Demon Eyes and figure if I could have my fogs on, I could also tap the demon eyes into the fogs, rather than having to turn on my parking lights and regular HID bulbs for a split second.
Anyone know or have an easy fix for this...or even better...a better way to tap the Demon Eyes so they're always powered upon start-up?
Thanks in advance! Excited to upgrade lighting (LEDs inside and Headlight Housing and Bulbs!)!
Old Feb 6, 2009 | 12:36 AM
Beebo's Avatar
there is a module... search for it
Old Feb 6, 2009 | 02:00 AM
Idyfohu's Avatar
Beebo...thanks, didn't even see that DIY.
Actually, that route seems like a pain and is a bit costly for the module...
Anyone happen to know the best source to tap into to have constant power once the car is on? This would be for my Angel/Demon eyes I'm planning on installing shortly. I'd prefer to not have them directly wired into the parking lights so that they'll automatically be on upon starting my car.
Thanks!
Old Feb 6, 2009 | 02:09 AM
SxExCx's Avatar
made by KP technologies
Old Feb 6, 2009 | 03:04 PM
seddon's Avatar
The foglight module by KP tech is not for the sedan coupe only.
Old Feb 6, 2009 | 03:43 PM
Idyfohu's Avatar
I'm not going to go that route as it's too spendy and I wanted it mainly as a switch to tap my Angel Eyes...
What would be best tap/splice to have constant power once the car is started?
Old Feb 7, 2009 | 01:06 PM
CanadianBird's Avatar
In Canada/BC running lights have to be on at all times. I drive with h.l. on at all times as it keeps the rear well lit. IMO
Old Feb 7, 2009 | 08:32 PM
ttrank's Avatar
Grocery getter
The KP module is for the coupe only. Kevin is still working on one for the sedan. I just tested his latest module and there are still some issues. If you know anyone with a sedan in the Ohio area who would be willing to let Kevin check some signals on it let him know!
Old Apr 22, 2009 | 08:17 PM
2QU1CK's Avatar
from the demon eyes, run the wire directly to the fuse box using any accessory fuse, wrap the power wire around any accessory fuse and reinsert the fuse, and just ground the ground-wire anywhere to the car. with all this done, when u insert the key, the demon eyes comes on, when u remove the keys, the demon eys comes off.....all with out touching ur lights switch. i like to use the fuse for the cigaret lighter.
Old Apr 23, 2009 | 03:09 PM
ttrank's Avatar
Grocery getter
Or you can just use the ignition signal wire that runs across the front of the motor to trigger a relay off direct battery power and not mess with going inside the car.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
Freddy07g35
Sep 17, 2015 08:53 PM
