Tail light removal help!
Old Mar 2, 2009 | 08:29 PM
Connor's Avatar
hey guys probably a stupid question but i've been trying to tint my tail lights but can't seem to take off the plastic tabs to remove the liner, i've tried a couple methods but nothing seems to work, is there a certain way to take them off?
Old Mar 2, 2009 | 08:58 PM
nghiars's Avatar
take a flathead to those tabs, there should be space for you to wedge the flat head under the inner tab. once you pop up the inner tab pull it out and pull out the other piece.. then you have 3 bolts to get the tail light assembly off
Old Mar 2, 2009 | 09:38 PM
g35freak86's Avatar
yup. I use a flathead screwdriver. Just insert the flathead in the groove and pop it up. It'll come right off
Old Mar 2, 2009 | 09:40 PM
Connor's Avatar
kk thx got that off, but now when i'm removing the tailight itself how do i remove the cord out the back of the light? im afraid of just yanking it, is there a lock on it or something?
Old Mar 2, 2009 | 09:43 PM
g35freak86's Avatar
there is a little piece of plastic you push up to release. It's on the underside of the plug. Push it in and shimmy back and forth. It will come off
Old Mar 2, 2009 | 10:55 PM
Connor's Avatar
thx a lot, saved me a lot of stress, well putting my first coat on now, ill put up some pics when i'm done
Old Mar 3, 2009 | 03:42 PM
ttrank's Avatar
Grocery getter
I always use a 45 or 90 degree pick to get those off.
What are you using to paint your tails? VHT, paint or?
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
