Turn Signal Issue.... Need Help
Old Mar 9, 2009 | 12:53 AM
VolFan's Avatar
Unhappy Turn Signal Issue.... Need Help
I have a 2003.5 6MT that I got last summer. The other day my dad was following me and noticed an issue with my turn signals. When I turn the signals on, both left and right blinkers start flashing similar to if the hazards were on and the brake leds turn on and off. The front signals are unaffected. I turned the car off trying to figure out what was going on once I got home and when I turned it on again, everything was working normal again. Today I was changing the oil and I decided to see what mood the signals were in and they were messing up again. Has anyone else seen this on their G or heard of this before?
Old Mar 9, 2009 | 06:25 PM
ttrank's Avatar
Grocery getter
Sounds like a short. Could be a short in the trigger wire, in the BCM that controls the turn signals..
If you don't have a warranty to fix the issue start simple, change the bulbs in both. If that does not fix it you may have to try to have the dealer dig into it.
Old Mar 9, 2009 | 07:52 PM
snotf's Avatar
if it does turn out to be a wiring issue, i HIGHLY advise going to the stealership... wiring is a PAIN.
Old Mar 9, 2009 | 08:44 PM
VolFan's Avatar
After some more observations, the signals didn't flash when I used the key fob. I would say this would eliminate a short in the trigger wire. When I had the car running and the signals were still acting up, I tapped on the left rear signal and it fixed itself. Being how soft I actually tapped it, I'm hoping its just a loose connector. I'll take a look at the wiring tomorrow even though I'm much more mechanically inclined than electrical. I don't have the money to take it to a dealer really so I'm hoping its something I can fix.
Old Mar 18, 2010 | 08:09 PM
pikepilot's Avatar
What did you find out? I am having the exact same problem.
Old Mar 19, 2010 | 08:25 AM
Blue Dream's Avatar
I drove ttrank's car solo
Last Activity: 04-21-2009 11:58 AM
You won't get a response from VolFan^^, maybe someone else can help. I do want to applaud you on searching to find a thread relevant to your issue. Great job by a n00b!!
Old Mar 19, 2010 | 08:32 AM
SedanManBen's Avatar
Well I had this issue in my Audi S4.. and it turned out to be a bad relay in the hazard switch?! Sooo I would highly advise taking it to an electrical shop.. NOT the stealership. They don't know squat about electrical usually
Old Mar 19, 2010 | 10:26 AM
VolFan's Avatar
Have some faith boys. I'm still around rockin the G, I just haven't posted anything in quite some time.
My problem was related to a loose grounding bolt. The bolt is located in the trunk, near the driver side brake light assembly. You will need to pull back the trunk liner to access it. The problem is that they put a machine screw into sheet metal and there just isn't enough sheet metal for the bolt to grab onto. To fix it, I simply put a bolt on the back side of the screw so that it would always get good contact. I actually found the issue by turning the turn signals on and I was able to hear the loose grounding wire arcing.
If you have any more questions, feel free to ask as I am still around
Old Mar 19, 2010 | 10:29 AM
^ ^ ^ ^ Super shocked you replied with only 2 posts!
Old Mar 19, 2010 | 10:39 AM
Blue Dream's Avatar
Yeah baby, the ultimate lurker!!! Glad you're still around.
Old Mar 19, 2010 | 11:01 AM
VolFan's Avatar
I thought I had already posted my fix when I figured it out before but I guess that was a different forum. I'll admit that I typically just pay attention to the marketplace and probably wouldn't have seen this thread pop back up if it hadn't been for the email alert for thread activity.
Old Mar 20, 2010 | 01:54 PM
pikepilot's Avatar
Thnks for the info. I will check out the grounding bolt. I knew a forum like this would work. I used one alot when I had my motorcycle. Thanks again!
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
NyCrAzY
Oct 1, 2015 09:19 AM
master111
Sep 25, 2015 08:32 PM
