Mods for sedan to improve gas mileage?
Old Mar 26, 2009 | 03:38 PM
  #46
Lucky-G's Avatar
My thoughts on the heater discussion--wouldn't running the heater full blast create a more efficient engine, as you're removing heat from the engine bay/water temperature?
Old Mar 26, 2009 | 03:42 PM
  #47
Jeff92se's Avatar
Red Card Crew
extra radiator? Yes. Worth it? no.
If I wanted a car to get good gas mileage in, I would have bought a Prius and then commenced to clogging up the left lane doing 55
Old Mar 26, 2009 | 03:53 PM
  #48
Lucky-G's Avatar
I agree whole heartedly about the G not getting great gas milage, and that it's not intended to do so. I was just chiming in on the heater/AC debate here.
Priuses are for men who have mangina's. If anyone watches Jeff Dunham, you know exactly what it sounds like to make fun of a guy with a Blue Prius
Old Mar 26, 2009 | 05:51 PM
  #49
HLMAX's Avatar
Like many have said, light and constant acceleration. The engine is very inefficient during acceleration.
Cut down the aerodynamic drag by avoiding excessive high speeds, keeping your car clean, keep windows close, avoid attaching appendages like spoilers or external decorative pieces to your car.
Avoid braking as much as possible. Your precious gas is converted to heat every time you brake. Time the lights and traffic. If traffic allows, coast instead of brake.
Turn off all unnecessary electrical device, such as lights, fans and stereo.
Keep tire pressure on the high end of specs. Get taller, narrow, stiff, low rolling resistance tires. Avoid sticky, low profile high performance tires.
Heck, all that takes the fun out of the G. That is why I am getting about 15mpg and enjoying it. Got to pay to play.
Old Mar 27, 2009 | 12:20 AM
  #50
godzillatreat's Avatar
Lose weight. Any weight that you can.
Old Mar 29, 2009 | 02:05 PM
  #51
joedaddy1's Avatar
Originally Posted by Riley
Regarding AC and heater...
Heater - sorry but that's a bit silly to not use the heater because of the fan. That's like saying don't turn on the stereo because of the power usage. This is really splitting hairs here and if you are looking to save that tiny amount of fuel, drive a hybrid.
AC - there's an interesting theory that when driving on the freeway in hot weather, it's better to use the AC then to drive with the windows down. The theory is that you loose more fuel due to increased wind resistance with the windows down and then you gain with the AC off. Just a theory that was tried to be verified on myth busters.
Better to drive with a lift foot and enjoy the car.
That's my 2-bits and I'm an Engineer (but I don't own a G37 yet.....but hoping).
o, i never said about how MUCH fuel the heater uses.. but i will bet you $1 million that the mpg you get with it on will be less than with it off.. whether it's 1mpg or 0.0000001 mpg..
Old Mar 29, 2009 | 04:15 PM
  #52
dofu's Avatar
20 Year Member
Screw the heater... if you care enough about maximum efficiency (or just looking to save weight on a track car, etc...) then take the heavy heater core out. The thing is at least 40 lbs in the engine bay... Just so nobody needs to ask, I never took it out of this car yet...
Old Apr 2, 2009 | 05:30 PM
  #53
danielw's Avatar
ok a little update. I did a few tests driving conservatively when i first got the car and got ~18 mpg everytime around town. I put in the k&n drop in and changed the oil to synthetic and my first tank got 21 mpg. Before anyone has a fit, I know there are all kinds of variables that could be slightly off here but there was an undeniable improvement in mpg no matter which way you look at it.
Old Apr 3, 2009 | 01:20 PM
  #54
MarkG's Avatar
Just a reminder that this is the time of year where many parts of the country switch to 'summer blend' fuel, which combined with warmer weather can add anywhere from 3 to 10% better economy.
Old Apr 4, 2009 | 12:08 AM
  #55
danielw's Avatar
^ interesting. had no idea.
TheefrshstVQ
Jul 26, 2015 09:37 PM
newg37
Jul 26, 2015 09:32 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
mushu
Jul 15, 2015 03:55 PM
