G35 Sedan Limiter
Old Jun 29, 2004 | 12:43 AM
bjast's Avatar
G35 Sedan Limiter
Is there a rev limiter on the 2004 G35? My wife had an interesting experince with our new G35 Sedan, that led me to ask this.
Thanks,
Bill
Old Jun 29, 2004 | 04:21 AM
Msedanman's Avatar
O.F. Administrator
Re: G35 Sedan Limiter
Yes our G's have rev-limiters. My Coupe's is set at 6600, and I think the Sedan's is same.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jun 29, 2004 | 01:37 PM
MOTOP's Avatar
Also if you have 5AT you wouldn't be able to go past 6krpm on last gear unless you have reflashed ECU. I tested.
***04 G35s 5AT/Sport***
***04 Volvo XC90 T6***
Old Jun 29, 2004 | 03:21 PM
3point5SE_Auto's Avatar
depending on how accurate your tach is (not very usually), the limiter may not kick in until you see 6900 rpm (Mine cuts in right there, many times)
Now downshifting or missing a gear can cause you to see 8000 plus rpm if you arent careful in a 6MT as the limiter is a fuel cutoff.
Speed is limited to 145 mph (mine has been to 149 without activating yet) but again the speedo isn't the most accurate either
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Old Jun 30, 2004 | 07:50 PM
slackeg's Avatar
Is this related to hesitation I detect (I think) when in 1st gear, (6MT) nearly floored and about to shift when ooomph, if I didn't know it didn't have a carburator I would swear the
float bowl sloshed or drained or something. First gear does not take long to redline but I am pretty sure I am not there when it occurs. And yes, sometimes depending on the road I maybe losing traction. Any tips on what I should observe more closely or just be satisfied with "things happen fast in 1st - besides there are 5 more!"
thanks
2003 G35 sedan(6 speed!)
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
