Hose temp too low for engine bay
Old Apr 8, 2009 | 04:50 PM
phrocker's Avatar
I'm replacing a hose in my engine bay. A local radiator shop gave me some excess hose, but its max external temp is listed at 90C. I asked the shop why the external sheathing temp was so lowly rated and he said it has some kind of coating that helps prevent cracking, so the rating refers to the coating's max temp. The guy did say the hoses crack pretty quickly w/o the coating, so I'd like some input. The outside sheathing is only gas and oil resistant, but I assume that's probably fine. I'm more concerned about the sheathing's max temp.
According to my searches, the maximum expected coolant temperature is about 212, so I'm guessing a free standing hose whose max temp rating is @ 195 is fine? I've always been curious, too, about what the max engine bay temp is under load.
Old Apr 8, 2009 | 04:52 PM
GreenGoblin's Avatar
The goblin resurrection
What are you trying to do? Just curious
Old Apr 8, 2009 | 04:59 PM
phrocker's Avatar
Replace a coolant hose. I noticed a small slit in it when cleaning my TB. I noticed a tiny amount of coolant coming out when the system was under pressure, so I went to a local radiator shop to get some hose since they usually have excess. It's on there now, but I thought I'd ask before I wasted time and money to replace it.
Last edited by phrocker; Apr 8, 2009 at 05:00 PM. Reason: and by TB, I mean tuberculosis
Old Apr 9, 2009 | 12:00 AM
Tollboothwilley's Avatar
What did the radiator shop tell you?
honestly, the cooling system in most vehicles is going to be very similar...if they use that type of hose on most cars I don't see why it would be any different.
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
