How loud are fan suppose to be?
Old Apr 23, 2009 | 02:06 AM
Tangerine's Avatar
Mine sounds like it is on full blast (no a/c with everything shut off) all the time. I tried taking a video but the sound is so distorted from my vid phone. Any idea how to check the fan?
Old Apr 23, 2009 | 03:07 PM
ttrank's Avatar
Grocery getter
Interior or radiator fan?
Old Apr 23, 2009 | 04:17 PM
Tangerine's Avatar
Radiator fan, with the hood open it sounds like a tornado.
Old Apr 23, 2009 | 05:05 PM
DJMaffei's Avatar
i can attest to that tangerine but im almost postive its normal
Old Apr 23, 2009 | 06:07 PM
DaveB's Avatar
What year G sedan? Which fan? What are the temps where you live right now? Are you certain the fan is on ALL the time or just in 1st gear time about 20mph?
Old Apr 23, 2009 | 06:17 PM
Tangerine's Avatar
50-70 degrees ish, its a 2003 and its during idle. Not sure about when it motion.
Old Apr 23, 2009 | 09:01 PM
DJMaffei's Avatar
around 50-75 degrees, 2006, during idol usauly, and i cant hear it over the reg. engine growls.
Old Apr 24, 2009 | 12:44 AM
str3zz's Avatar
If your fan is mechanical fan, CHANGE THE FAN PULLEY BRACKET SINCE THE BEARINGS PROBABLY WENT BAD AND SHAKING WHEN THE FAN RUNNING BEFORE ITS TOO LATE LIKE MINE AND COST ME A FORTUNE TO FIX IT. If u don't replace it asap the bolts that holding the fan clutch and pulley will fail and flew to your radiator and will be big mess.
I heard that noise and I ignore it and cost me close to $700 to fix it by my self. Just imagine how much dealer / added labor charge to it.
Also check your fan cluth bearings to hold the blades see if its also shaking badly.
Hope this help. More info go to infinitipartsonline.com for more detail and diagrams.
Old Jun 9, 2009 | 02:37 PM
tite_tite's Avatar
it's the fan clutch...i had the same problem as well..."tornado sound" was what i called it too...it was spinning so strong & powerful, it made a scratch on my radiator(luckily my radiator is fine)
a bad fan clutch will slow your performance as well...
good luck
Old Jun 9, 2009 | 05:47 PM
Mustang5L5's Avatar
Mechanical fan? The fan clutch has failed
Old Jun 27, 2009 | 07:59 AM
lowblocks's Avatar
i have the same problem with mines so what do i do just go to the junk yard and replace the hole fan?
Old Jun 27, 2009 | 01:29 PM
tite_tite's Avatar
you would need to get the fan clutch. it is the part in the middle of the fan blade. your fan blade is fine. you just need to get the fan clutch.
Old Jun 30, 2009 | 09:48 PM
thescreensavers's Avatar
Mr.202?
Really I thought this was normal. Mine does as well but I think it stops once my car warmed up when I was idle for that long.
how do you know if its a Mechanical fan or a normal fan idk.
Does warranty cover this? it should.
Old Sep 26, 2015 | 09:20 PM
tiguy99's Avatar
How can you tell which fan you have? I have a 5AT
Old Sep 27, 2015 | 01:32 AM
5150DS's Avatar
05 is electric fan
