2nd gear stall at redline
Did anyone had this problem in the auto? I use the manumatic shift today, and hit the 2nd gear to redline. However, it starts to stall, and eventually comes back when the rpm lower than the redline. anyone, please help...
Thanks, Buche Nothing Turns You On More Than The "hotGspot" |
Re: 2nd gear stall at redline
You hit the rev limiter.
It's there to protect the engine from over reving <font color=blue>04 Silverstone G35, 5AT, Prem, Aero ES100 225/45-18 front 245/40-18 rear Borla TD, Z-tube, Eibach, 35%Tints</font color=blue> |
IC...thanks...
I freaked out the first time I hit the rev-limiter. Took it all the
way past redline and the rpm just dropped like a rock. Sure is a nice safety feature. 2003 TwBlue 5AT Sedan, sunroof, Graphite Leather, splashguards, HKS exhaust, 14 wire Grounding kit, 350Z duct, Stillen CAI Underbody rear diffusers, Drilled alum pedals |
You will find the sweet spot for shift points with time & practice.
The difficult part is that the shift seems to lag/delay more with load. Generally I find that under WOT you need to shift at aprox 500 revs sooner than target shift point. e.g.Under WOT to hit a 6500 shift point, make your shift @ 6000 rpm <font color=blue>04 Silverstone G35, 5AT, Prem, Aero ES100 225/45-18 front 245/40-18 rear Borla TD, Z-tube, Eibach, 35%Tints</font color=blue> |
