tail light fuse keeps blowing, anyone know why?
Old May 18, 2009 | 09:07 PM
jtguns's Avatar
found the fuse for taillights behind battery blown replaced it as soon as put it in and turned on headlights to see if they worked blows right away i tried with battery disconnected also same results??
Old May 19, 2009 | 10:21 PM
seankim513's Avatar
i had problem with brake fuse inside kick panel.i tow to dealer they find out and they blem me i had after market navi and rear wing.so if you have rear stolier try to back to 3th light .once kick panel brake fuse blow your car will not move so if at selector not moving check this.
Old Sep 28, 2011 | 10:53 PM
westbank23's Avatar
Bump!
I'm having the same problem.also the dimmer lights go when the tail lights go.
Any solution?
Old Sep 28, 2011 | 11:35 PM
seankim513's Avatar
Originally Posted by westbank23
Bump!
Any solution?
do y have rear wing(aftermarket) any mod headlight?
if y had mod on headlight you got to remove battery and check LIGHT CONTOL FUSE . if have ccfl light check converter maybe need replace ccfl converter.also y need disconect 3rd brake light if y bypass to rearwing light.
Old Sep 1, 2012 | 03:16 PM
Kevinvooo's Avatar
Have you guys sound the solution for this yet? Im having the same problems with my tails. And Now my car wont start!!
Old Sep 19, 2012 | 07:41 PM
si_driver's Avatar
Sedan or coupe?
roboeclipse
Lights
Aug 13, 2015 10:45 PM
Danielek
Aug 11, 2015 09:33 AM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
