Will Cipher work on early 03 sedans?
Old May 20, 2009 | 10:14 AM
GT-ER's Avatar
I emailed uprev once and never got a reply. Will it work on early 03 sedans with the different ecu?
Old May 20, 2009 | 10:31 AM
DaveB's Avatar
Nope.
Old May 20, 2009 | 11:19 AM
GT-ER's Avatar
Originally Posted by DaveB
Nope.
Crap...I can't even log what's going on in my engine? How do I even know if my Trottle body is opening completely or if I have knock without using a bad *** scanner?
Old May 20, 2009 | 01:39 PM
Jeff92se's Avatar
Red Card Crew
I believe the Cipher will work but the Osiris reflash will not. But I'll confirm soon
Old May 20, 2009 | 02:36 PM
GT-ER's Avatar
Please let me know if you find something. I want a scanner and cipher is a good price.
Old May 25, 2009 | 11:34 AM
GT-ER's Avatar
Any news Jeff?
Old May 25, 2009 | 12:20 PM
DaveB's Avatar
If you're simply looking for a good OBDII scanner, then consider OBD Scan from Harrison RD http://www.obdscan.net/ It's far cheaper than Cipher and has the same capabilities except it won't change timing advance 2 degrees like Cipher. I've run the Harrison RD unit since 2000 and it's been great. It's worked on every 1996+ Japanese import I've worked on including Hondas, Toyotas, Nissans, Subarus, and Infinitis.
Old May 25, 2009 | 04:24 PM
GT-ER's Avatar
I don't care much about the timing adjustment but I do care about idle adjustment and capabilities for reading live data like knock detection and timing advance. Do you see any limits ( other than timing adjustment ) that cipher doesn't have? The price is great I have to admit.
Old May 25, 2009 | 06:30 PM
TurTLe*'s Avatar
almost all OBD2 scan software can give you live data. idle adjustments... no or timing adjustments. that is only cypher i think.
blaztZ is another good software i've seen in the sub $200 range. its specfic to nissan. All software i've seen is sub $200 other then cypher.
I dont know if i want to go with a nissan specfic of a generic type of software. I'm sure this isn't my last car i'll buy so i didn't want to be stuck with useless software. $200 can get me a little extra in specfic nissan or generic everything.
Autoenginuity seems to be something that has HIGHLY peaked my interest. Overall i think i'm going that route since if i get the nissan/infiniti package i can operate some of the AWD stuff on my X sedan.
Old May 25, 2009 | 07:23 PM
03Sg35's Avatar
Cipher worked on my 03 doggy door, car has build date of 12/02. Some features wont work like the BCM features. I was able to ajust idle and check some other stuff out. You wont be able to read any A/F data since 03 dont have the O2 sensor capabilities.
Old May 25, 2009 | 08:43 PM
Tollboothwilley's Avatar
Cipher works with any car
Osiris is limited in its use to 2004.5 +
Old May 25, 2009 | 11:32 PM
GT-ER's Avatar
Nice, thanks guys...
Old May 27, 2009 | 03:13 PM
TurTLe*'s Avatar
so what are you looking at getting? still cipher?
Old May 27, 2009 | 04:46 PM
GT-ER's Avatar
For the moment yes...raising the idle speed is a must for me since I'm gonna be getting poly engine mounts and advancing timing is a nice plus. If I can get another scanner that can do this for less than Cipher then I'd hit it.
joedaddy1
Jul 28, 2015 02:58 PM
Rehman2009
Jul 27, 2015 03:23 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
