Best glue to hold that thin black plastic strip at base of door.
Old May 20, 2009 | 06:07 PM
G35NC's Avatar
Part of that very thin black strip of plastic molding is hanging from my door trim. It's the strip that lines the base of the doors. Very little of the plastic comes in contact with the car body so I need to know what may be the best glue to hold that.
Thanks for any tips.
Old May 21, 2009 | 06:30 PM
skazz781's Avatar
I used crazy glue just make sure you don't put too much and don't close the door after you apply it. I made that mistake and when it dried and I opened the door the black trim came ripped off lol. But when I close the door again it looks normal.
Old May 22, 2009 | 12:36 PM
Julio00017's Avatar
Yeah, that little strip is hangin off my door too. I gotta fix that, it bugs the hell outta me.
Old May 22, 2009 | 03:26 PM
h23sdominate's Avatar
me too it pisses me off so much so i just tucked mine up under the door
Old May 22, 2009 | 05:49 PM
STCLAIRWEST's Avatar
I think i have the same problem, is it bad to super glue it?
Old May 23, 2009 | 10:21 PM
jude26's Avatar
Would guerilla glue be too much?
Old May 24, 2009 | 02:12 AM
G35NC's Avatar
Wow! I had no idea this was that common of a problem. Anyway, I bought this 3M product called Plastic Emblem & Trim Adhesive (part #03601), and it worked flawlessly. Be sure to run the bottom edge of the door with rubbing alcohol to remove dirt or wax, also rub the back of the trim but make sure it's dry before applying the glue. Apply a light amount with a q-tip, toothpick or very small brush. It bonded in 2 minutes!
Old May 24, 2009 | 04:22 AM
probably not but the glue isn't the problem its the fact that there is such a small area that you can actually apply the glue
Old May 24, 2009 | 11:27 AM
naughty240's Avatar
Its covered under warranty if you still have it.
Old May 24, 2009 | 01:23 PM
jude26's Avatar
Really. My car is getting serviced now, I'll see if i can get it fixed.
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
Frostbite91
Aug 20, 2015 07:20 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
