Quick-e question for sedans with Infiniti M sport wheels
Old May 28, 2009 | 02:33 AM
O4G_ride's Avatar
So i have the 19"s and am running a 10mm spacer with extended studs in the front... I hear i can run a 10mm or even a 15mm in the rear... right? Okay... if the answer is yes... What's safer or works better the Ichiba spacer with seperate extended studs or the V2 ( i think it's called) with studs on the spacer itself? Any suggestions...
Old May 28, 2009 | 09:38 AM
FlyingLumpia's Avatar
Yes you can a 15, as for safer some people say the ones that you have to replace the studs are better but I run with the build in studs and I havent had any problems. Just make sure you torque them down right.
Old May 29, 2009 | 01:42 AM
O4G_ride's Avatar
thanks cuddy...
where can i get a Ichiba V2 15mm spacer for a good price? Also... would i have to remove the old studs if im using this style V2 spacer... or how does the rim sit flush onto the spacer without rubbing on the stock studs??
Thanks
Old Jun 24, 2009 | 02:34 AM
O4G_ride's Avatar
Cool I went with th 15mm spacers in rear...
Possibly not the best choice... They slighlty rub on tight turns... Quick note to self: Go with 10mm all around...
Old Jun 24, 2009 | 04:25 AM
butkiss1's Avatar
Rollin this setup with no spacer , Had a 5mm but after close ( I mean really close inspection) Im not rubbing at all Maybe its the tires i'm using .
Vredestein Sessanta 245/40/19 I'm also dropped on a 06 350z Shocks Springs & Struts. By the way wheels and tires are for sale
rezendvous420
May 31, 2020 01:26 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Brodys_GCoupe
Nov 7, 2015 08:06 PM
multimut
Canada
Jul 26, 2015 08:43 PM
