Summer heat, are you guys feeling power loss?
Old Jul 8, 2009 | 02:10 AM
Awilli's Avatar
I really don't notice much of a difference even here in So. Cali (Today it was 94) , I have the Stillen 2 core radiator,deep oil pan, a flex a lite exsternal trans cooler, a motordyne planum spacer and I eliminated the mechanical engine fan (It would'nt fit with the bigger radiator anyway, did my own fan mod utilizing the stock 6 speed manual dual electric fans). Just drove from Vegas Monday, average temp 107, highest temp 113 A/C set at 77, cruse set at 79. New cars are real sensetive to heat or cold variances and detonation, anything done that maintains a 200-210 deg. temp range helps.
Old Jul 8, 2009 | 02:32 AM
dofu's Avatar
20 Year Member
Only when the A/C is on...
Old Jul 8, 2009 | 06:38 AM
butkiss1's Avatar
try adding a coolant control valve(CCV) and a lower plenum iso thermal Gasket, helps quite a bit ,i have both of those mods .My buddy just has the md iso thermal plenum spacer,,there is a big diff in our ,plenum temps
Old Jul 8, 2009 | 05:07 PM
H0TEP's Avatar
Don't really drive the car too much out here, but the couple times I have it's definitely felt a bit slower.
In a place like Hell a.k.a. Phoenix Arizona, would a cold air intake be recommended or best to stick w/ something like the stillen airbox?
Old Jul 8, 2009 | 07:10 PM
OCG35's Avatar
Its simple physics… cold dense air has more O2 molecules… oxygen is needed for combustion, the more oxygen the better the combustion – so long as the a/f is proper you will have more power… hot weather = expanded oxygen molecules (less per any given volume)… this is why ppl go to great lengths to make the intake air as cold as possible (Motordyne Isothermal kit, cold air intake, iced plenum, etc… and various means of dissipating engine & header heat)
So yes, when it’s hot outside you will feel a bit of power loss compared to colder ambient temps.
Old Jul 9, 2009 | 05:42 PM
HNDREDOLABILG35's Avatar
Originally Posted by jakeup93
I understand what you are saying DaveB but it is very noticeably different when it is say hot or cool outside...just like with almost any car. I don't know if the throttle is more relaxed in hot weather or if its just heat soaks OR something wrong...but its a really crappy feeling. It's very sluggish off the line in this heat.
i have noticed the same thing.......its been the same here as far as temp goes about 80f-90f
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
