19' rays on AWD?
Old Jun 25, 2009 | 09:41 PM
350GT-R's Avatar
Originally Posted by Mustang5L5
Nope, because a 245/40/19 is 26.7" in diamter and a 275/35/19 is 26.6" in diameter. The difference is negligible..it's 2.5 millimeters. No different than haveing low tread in the rear. Whether or not you can fit a 275 into the fenderwell is a different story.
So both tires would be turning at the same speed. The AWD and ABS won't know it at all.
Unsure what the specs are to trip the AWD or ABS faults. With most cars, ABS is around 3% difference in rotational speed, but i don't know the specs on the G35 at all.
are we comparing it by how wide the wheels are or how high it is to the fender?
Old Jun 25, 2009 | 09:55 PM
Mustang5L5's Avatar
That's where the confusion comes from.
Width of tires doesn't matter...all that matters is how tall the tire is from the ground up.
I wish i had a diagram to better explain it. Basically, if you roll both wheels, they need to cover the same distance on the ground. In other words, if the rear wheel spins 300 times in a mile, the front needs to also spin 300 times.
Width doesnt matter...it only matters in terms of tucking up into the fender and looks.
height from ground to top of tire matters. Rolling distance.
Old Jun 25, 2009 | 11:35 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Originally Posted by Canuck
I have a 2006 DG G35x sedan with 19" coupe Rays (8" front, 8.5" rear). I wrapped each corner in 245/40R19 Yokohama s.drives. I have experienced no problems with the VDC or AWD system. Also, there is no rubbing.
The only drawback of this setup is the inability to rotate tires.
You can do a tire-dismount, tire-only, rotation.....leaving the wheels in place since you have the same size tires. I will do that on my next set of tires. 245/35/19 on all 4 corners. I will do a rotation twice a year and I bet I will get 3 yrs from them vs 15 mo from my current ones.......Avg. tire expense will go down from 1k bucks a year to $526 a yr incl the cost of dismount-mount/tire-only rotation. That is unless they say I can only dismount and mount a couple of times and then I'm screwed.
Old Jun 25, 2009 | 11:51 PM
TycoRC's Avatar
Infiniti G35 Sedan Nismo Aero Sport Package
Simple as is! My buddy has a G35X with oem 19s, runs the staggered 19x8 19x8.5 225/40 up front and 245/40 rear no problem still runs the same no issues other than rolling the rear panels.
Old Jun 25, 2009 | 11:52 PM
350GT-R's Avatar
AHHHHH!!!! I GET IT NOW!!! THANKS!!!!
Old Jun 25, 2009 | 11:55 PM
350GT-R's Avatar
how bout if i get those, 19x9 front and 19x10 rear? but its 245 all around? will that be okay?
Old Jun 25, 2009 | 11:59 PM
FlyingLumpia's Avatar
With that set up run a 225/40 f 255/35 rear. Nice semi stretched look.
Old Jun 26, 2009 | 11:05 AM
blklude98's Avatar
I'm running 225/40/19 and 255/35/19 like some other here...no problems with VDC because they are the same diameter. NO problems with Rubbing either on the Z/G springs, even with a full load in the trunk and back seat.
Old Jun 26, 2009 | 11:52 AM
But you dont have an X
Old Jun 26, 2009 | 12:58 PM
Mustang5L5's Avatar
It still matters somewhat for the ABS.
I used to toss HUGE drag radials on the back of my Mustang to go to the track for the day and the nearly 2" differnce in diameter would be great enough to fault the ABS and disable it until i put matching wheels back on.
Granted, i don't really think anyone wants to run wheels with a HUGE difference all the time. In terms of ABS, a 1/2" difference or so should still be in it's window of functionality.
When it comes to AWD, i strongly suggest you get it as close as possible. Any slippage in the transfer case due to different sized wheels is wear...plain and simple.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
cmesidewayz
Sep 29, 2015 09:28 PM
leo38cheng
Sep 25, 2015 01:47 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
