Noob question
Old Jul 29, 2009 | 02:50 PM
kevin3751's Avatar
Noob question
I cant seem to find the answer but.. Im going to buy new rims and tires, but I am a little confused on offsets .
- Im getting 20's
- non-staggered 245/35/20 all the way around
I was wondering what size rims can fit on these tires and what offset i should get that would fit on my car...Thanks in advance
Old Jul 29, 2009 | 03:45 PM
Texasscout's Avatar
245's will fit on rim widths of 8 to 9.5" I'm running 19" by 8" rims with 245 series tires and they fit perfect. I don't know how wide you can go with 20's, that's a function of your offset and width. As for off set, I run a +30 on mine and I get a nice flush look. I can't get a finger between the tire and fender in the back. With 20's, you may want to run +35 or roll the fenders in the back.
How about some of you other seday guys chime in?
Old Jul 29, 2009 | 05:53 PM
mesias's Avatar
I run 4 rears coupe 19" 8.5 wide which have +33 off set and they run very nicely flush to the body. I also run 245 but with profile of 40. Try the following chart, it will give you a better perspective:
Old Jul 29, 2009 | 06:10 PM
Texasscout's Avatar
Not too sure about that chart, I'm running +30 and 8" rims in the back and it's just inside the fender line.
According to that chart, they shouldn't fit.
Old Jul 29, 2009 | 06:37 PM
mesias's Avatar
That's about right. Look at where it says "8.0 +33 - OEM 17" 350Z/G35 Coupe Wheel (R)" The wheel should be inside the outside fender line.
Old Jul 29, 2009 | 06:50 PM
NjMatteSedan's Avatar
so what offset range should i be looking at for a perfect flush look for 20" by 9" and 20" by 9.5? cuz when i buy my next set of rims they're gonna be either 9 or 9.5 in the rear with 245/35/20 i wanna know what range of offset is the best for the tire to be even with the fender and the rim pokin out
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
