Will these wheels fit? ( have my doubts)
Old Sep 27, 2009 | 03:45 PM
G SEDAN's Avatar
^ no it wont. I have 10.5 +40 on 20s and it cleras the strut tower by about 10mm.
The rears will fit but fenders will need to be rolled. 245/35/19 is gonna be super stretched on a 10.5 rim so that will give you clerance as well.
I have to caution you...if your car is not low, it ill look super retarded. Just a caution.
fonts will do fine, actually the offset a bit high, but will be close to flush due to 9.5
Old Sep 27, 2009 | 03:54 PM
6spSEDANFTW!'s Avatar
hey OP rims look SICK!
i dunno if this will help u, but im running in the rear 20x10 +45 275/30/20 with rolled fenders AND a 5.5mm spacer right now and i do not rub
but man, rims look SO SICK! if u get them i think u will have on sick sedan!
Old Sep 27, 2009 | 04:39 PM
Dark_'s Avatar
I've got 19x10 +38 and they barely rub the lock ring on my BC rear shock when the wheel begins to tuck.
Your wheels should be way more than 10mm from the strut towers though.
Old Sep 27, 2009 | 04:44 PM
sweettalker's Avatar
I don't know if anyone else noticed. Doesn't the lip color seem off? Did you check these out in person? Also why is the lip so minimal? I have seen those wheels in person but they don't look like that in person. Little details like the lip seems to be not polished and the lip size seems way too small for such wide wheels. It almost seems as if the wheels are all same size width and offset wise
Old Sep 27, 2009 | 05:27 PM
G SEDAN's Avatar
i have .5 inches wider wheels. That adds a quarter to inner and a quarter to outer, which equates to 6 mm each side.
Since my offsets are 2 mms higher than you, I am also 2mm closer to the strut. add the 6 mm wider on the inside. I have am about 8mm closer to the strut than you.
If you're rubbing technically I should be hitting. but luckily, I am about a finger gap away from hitting.
Old Sep 27, 2009 | 05:58 PM
4DGS's Avatar
I'm on H-techs now, but I plan to go to S-techs soon. Think that would be low enough to look good? Would the H techs do? Coilovers are in the future but not for a while.
Sweetalker, I am yet to see them in person I'm going to check them out sometime this week. The colour isn't off it's just a weird photo. The lip size confused me too, but that's ok because I hate deep lips.
Old Sep 29, 2009 | 01:33 AM
bbs350z's Avatar
Originally Posted by 4DGS
Found some Volk GT-Vs for a decent price and local. They are pretty fat though.
Will these fit on my 03 sedan? I can get the fender rolled.
Front: 19”, 9.5” wide, offset +40
Rear: 19”, 10.5” wide, offset +40
Front: Toyo Proxes-4, 235/35-19
Rear: Toyo Proxes-4, 245/35-19
how stretched would a 245 rear be on a 10" rear?
Old Sep 29, 2009 | 06:41 AM
Dark_'s Avatar
Next time the wheel is off I'll take a picture of the lock ring.
Old Sep 30, 2009 | 12:47 PM
snotf's Avatar
buy nao pics immediateness!
Old Sep 30, 2009 | 01:18 PM
PAIXAO's Avatar
While we're on this topic how will 19x8.5 +25 look up front and 19x9.5 +29 look in the rear on a sedan??
Old Sep 30, 2009 | 01:24 PM
4DGS's Avatar
They will look a tiny bit sunken. Might need some 10ishmm spacers. It will look fine without spacers though too.
Old Sep 30, 2009 | 01:25 PM
PAIXAO's Avatar
Thanks man. Maybe I'll look for a larger offset.
Old Sep 30, 2009 | 01:50 PM
4DGS's Avatar
Well if you're getting a deal on them just slap some small spacers on.
Old Sep 30, 2009 | 02:04 PM
Jeff92se's Avatar
Red Card Crew
With 4mm less offset and 1" wider, what tire would you use? I'd say a 265-35 at the min?
My coupe 19s 19x8.5 with 33 offset and 245-40s. Not very low with coupe springs:
Old Sep 30, 2009 | 04:00 PM
  #30
1SlowSedan's Avatar
To the OP i doubt it'll fit in the front, I'm pretty sure you'll have problems turning. With 20 mm spacers? Yes, but ask Grant first.
