Warranty About to Expire - List of things to check?
Old Oct 12, 2009 | 12:43 PM
TIAN's Avatar
Hold The Line
Anything else that I should take notice of? Im gonna head for my last warranty check in
Old Oct 14, 2009 | 04:19 PM
awong's Avatar
keep it going guys bUMP
Old Aug 1, 2010 | 06:07 PM
awong's Avatar
bump
Old Aug 1, 2010 | 06:12 PM
alfhasg35's Avatar
oil consumption
rip or tear on the driver seat
rearview mirror paint comes off the button
gas tank doesn't fill all the way due to sensors or something
door actuators
window motors
compression rods
clutch sticking due to faulty slave cylinder
alot of these are TSB's
Old Aug 1, 2010 | 06:33 PM
awong's Avatar
they will do compression rod under warranty?
Old Aug 1, 2010 | 06:55 PM
alfhasg35's Avatar
i believe so if they are knocking or cracked ...
Old Aug 2, 2010 | 11:07 AM
davetres's Avatar
Will they replace compression rod if I have BC coilovers with a drop? Should I put it back to normal height with the coilovers?
Old Nov 3, 2010 | 05:07 PM
biochemist's Avatar
My warranty ends at the end of the year. I only have 23000 miles on it. I haven't experienced any of the symptoms listed so far- with the rocking seat or the creaking from the front end. I guess I should try to drive a bit more and hopefully (not) these problems will surface.
I've had exterior door mouldings replaced because they've detached from the double sided tape, but other than that, maybe a slight tear on a rubber seal on the driver side door which will likely be replaced and the plastic tab on the trunk that's warped, bent from separating from the double sided tape.
I assume the stealership will charge me if I ask them to take a look at the coilover covers and the compression rods without presenting them with any symptoms, right?
Old Nov 3, 2010 | 05:22 PM
vp-g's Avatar
gas door
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
derres
Aug 28, 2015 03:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
Detailed Image
Aug 3, 2015 02:51 PM
