G35 won't start!
Old Dec 18, 2009 | 06:33 PM
NFSP G35's Avatar
? = 2B || !2B
^ Good point.
OP Try eating a bananna
Old Dec 18, 2009 | 11:10 PM
SANTOS29's Avatar
LOL about the banana suggestion , about the problem sounds like you don't have enough power coming from the battery, do what everyone suggested check the terminals, you can also check to see maybe your parking lever it might not be engaged all the way, try moving it from park to neutral and try again, also I might have missed this, but you haven't install anything new in the car have you?.
Old Dec 19, 2009 | 02:32 AM
iTzTeddy's Avatar
Whats wrong with a banana? they are full of potassium and very delicious lol. Santo, i hate you and your g37 =[
Old Dec 19, 2009 | 08:25 AM
jimmyc13's Avatar
Originally Posted by Wrathernaut
I don't see it mentioned, but you have checked the oil level, right?
Are you saying if there's low oil or no oil at all, the car won't start or starter won't even work? Never heard of that before...
Old Dec 21, 2009 | 08:07 PM
High On G35's Avatar
I finally got my car back with a new starter and it's starting right up now.
Hope it doesn't die on me again!
Old Dec 21, 2009 | 08:35 PM
TurTLe*'s Avatar
when you have low/ no oil there is no lube at all. metal to metal contact, after a while it just locks up the motor, after damage has occurred.
Old Jul 7, 2012 | 02:02 AM
Natmats's Avatar
Originally Posted by High On G35
tried to jump it but nothing still. Hope its just a bad start and nothing serious.
i'm having the same issue. just be sure we have the same problem, this is what happens in my situation. i put the clutch in, turn the key to ACC (radio and all other electronics turn on), turn it further to turn over (all electronics turn off), no sound.
so i did some research on the nissan/350z forums too and i came across some other possible solutions. check out the following link.
http://www.nissanforums.com/ga16de-1...on-switch.html
it could be the IGNITION SWITCH.
i'm actually going to take into the shop tomorrow..
Old Jan 13, 2016 | 10:50 AM
m17davis's Avatar
Originally Posted by str3zz
Try to use your key to the driver door and lock/unlock 5-7 times and after that try to start the car again to see if it will start the car. if not call your local infiniti and ask them since sometimes they will give you some idea and or even free toeing service to bring it to them.
Good luck
This just worked for me! Thank you!
Old Apr 13, 2018 | 06:15 PM
Zaitta'sG35's Avatar
I dont know if my question relates but i have base model 04 g35 coupe (auto) i had a rod knock problem on my way one well while on the way home the car shuts off and wont start it wanted to but it sounded like it wasnt getting enough power to crank so i pushed it home and im jus getting around to looking at it i bought a new battery but the car just makes a clunk noise when i turn the key over i pulled my starter took it to autozone to get tested and it passed so could anybody throw any ideas out there to what it can be thats giving me this headache??
Old Apr 13, 2018 | 06:21 PM
telcoman's Avatar
Veteran: Army
Ever check your oil?
Possible engine seizure?
Does it crank/turn over when you remove the spark plugs?
Telcoman
Old Apr 13, 2018 | 06:31 PM
Thing is i changed the oil two weeks prior to it turning off but i honestly havent checked those things because im getting ready to buy a used motor for the coupe from a dismantler but i was jus asking because i want to make sure i dont need to fix anything else after my swap im taking the car to a buddy for the swap but i cant get the car on a trailer without it starting 😠😠
Old Apr 13, 2018 | 06:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep, pull the spark plugs and inspect then try to turn the crank by hand to see if it's seized.
Old Apr 22, 2018 | 12:32 PM
ls1camaro4's Avatar
Newbie
weird. My car is doing the same thing and I also just had my oil changed 2 weeks ago..
chinee
Jun 10, 2024 07:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
