coolant question..
Old Dec 31, 2009 | 02:50 AM
socialconflicts's Avatar
coolant question..
so the other day i noticed my coolant was near the "min" part... so i went ahead and added some... thing is i added way too much.. and the lil tank was a bit over the "max" line... is this bad?
Old Dec 31, 2009 | 09:58 AM
G35fromTO's Avatar
No. But... you might have some coolant overflow from the reservoir tank when the coolant in the radiator heats up and flows into the reservoir. It's not under pressure in the reservoir tank so it will just drip out and make a little mess around the tank which you should flush with water. You might end up smelling some of it inside the car when running the fan, but eventually it will pass.
You can always get one of these and draw the extra out: http://www.torcavettes.com/tech/clut...zerSyringe.jpg.
Old Dec 31, 2009 | 11:44 AM
bigc's Avatar
Wings Nation
you can siphon the extra coolant out with a $2 turkey baster or battery filler.
Old Dec 31, 2009 | 12:30 PM
Tollboothwilley's Avatar
or, you can take off the one bolt that holds the reservoir down, lift it up and disconnect that little hose for just a little bit so that the coolant comes out
MrIP35
Oct 25, 2015 11:13 PM
BradMD_96
Oct 6, 2015 09:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
DRG35R
Sep 16, 2015 05:33 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
