is this correct? info came from dealer
Old Jan 12, 2010 | 02:49 PM
socialconflicts's Avatar
i just got off the phone from kearny mesa infiniti and the sale manager told me that i dont need to worry about the tranny flush and differential change until 60k miles. the only thing he mentioned that would porbably need inspection would be the incabin filter since he had no history on that.
i have read throughout the forum that tranny flush and differential change should be done at 30k correct? just confused a bit on exactly what should be performed.
but what do you guys think?
Old Jan 12, 2010 | 02:59 PM
Mustang5L5's Avatar
I did my diff's at 40K and the rear was dirty fluid.
Trans fluid..i would prefer to do it prior to 60K...at least a drain and flush. Doesn't hurt to overmaintain.
Cabin air filter should be done...but it's not something you need a dealer to do. Autozone sells them for $15 or so and it takes literally 15 mins to change yourself behind the glovebox. Dealer quoted me $190 to replace this part. I just do it each spring before the pollen starts to fly and i'll need my A/C for the summer.
Old Jan 12, 2010 | 03:02 PM
the cabin i will do, ive seen the DIY and i dont think its worth spending 100+ on this service, i guess i can always spend a few extra bucks and just keep things sleek and clean. thanks for the info
Old Jan 12, 2010 | 03:05 PM
azt108's Avatar
There is also a DIY on how to change the diff fluid, might want to look into it.
Old Jan 12, 2010 | 03:11 PM
Mustang5L5's Avatar
Rear diff is very easy to do on your own either. Auto parts stores will sell the pump you need. 1 hour and done for cost of fluids and initial cost of pump/drain pan and jackstands if you don't have that stuff.
Old Jan 12, 2010 | 03:12 PM
yea im planning on doing these on my own and will purchase jacks from craigslist
Old Jan 12, 2010 | 03:38 PM
thescreensavers's Avatar
Mr.202?
Imo Belts,Tranny Fluid, Diff Fluid, Coolant flush, Incabin and Engine Air Filters.
for 30k
Preventative maintenance, always a good idea.
Old Jan 12, 2010 | 06:54 PM
Mustang5L5's Avatar
If iy you really want to be complete, bleed the brakes, and do a turkey baster drain and refill of the power steering fluid.
Old Jan 12, 2010 | 07:22 PM
for 30k
belts? does the G use belts or a chain? i know nissans use chains.
Old Jan 12, 2010 | 07:56 PM
Mustang5L5's Avatar
Timing chains
He means replace the two external accessory belts
Old Jan 13, 2010 | 06:52 AM
Blue Dream's Avatar
I drove ttrank's car solo
Have you ever looked under the hood of your car?
BTW your car is Lakeshore Slate, not Blue Slate, IMO the best color ever on a G . Might want to update your sig.
Old Jan 13, 2010 | 10:18 AM
Wannabe6MT's Avatar
-MN G Crew-
^+1
Old Jan 13, 2010 | 10:27 AM
B T's Avatar
B T
And lubricate your hood hinges before it's a problem
jeffbdye
Jun 1, 2018 03:51 PM
f22raptor
Mar 18, 2016 08:50 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
