where can i find this?
Old Feb 25, 2010 | 01:26 AM
socialconflicts's Avatar
hi guys, so i recently noticed that my Infiniti eblem from my fob fell off.. i never noticed it fall so was wondering where i can find one so i can glue it on myself.
heres a pic of what i mean
Old Feb 25, 2010 | 02:50 AM
Dacket84's Avatar
I'm pretty sure you can't buy the emblem by itself. You'd have better luck buying an extra fob off of ebay and programing it to your car and keep your current emblem-less fob as an extra backup. Or just swap the emblem if you're to lazy to reprogram.
Old Feb 25, 2010 | 02:57 AM
hehe yea, but would like that to be my last resort... to program a fob is expensive >.>
Old Feb 25, 2010 | 03:11 AM
Dacket84's Avatar
Sometimes dealers will do it for free, just ask how much would it cost to have it done and if they give you a price then say thanks and leave. Otherwise if they're bored they'll say, "Oh phfft, I can do it for free". At least that's the way it went down with my Lincoln.
I haven't looked into programing fobs for these cars, but sometimes its just a series of key turns and door lock & unlocks then pressing a button on the fob then its programmed.
Though I'm sure its a little more involving considering its an i-key.
thescreensavers's Avatar
Mr.202?
just forget it imo. That key stays in your pocket the whole time any how :P
Old Feb 25, 2010 | 03:24 AM
omg! you dont know how much i put this through my head LOL! but then again it bothers me to just look at it.. LOL
its bad..
Old Feb 25, 2010 | 03:27 AM
Dacket84's Avatar
Lol sometimes you just can't ignore the little things...
Old Feb 25, 2010 | 08:26 AM
Mustang5L5's Avatar
Mine is the same way. The emblem is falling off. My other fob is brand new, but i don't want to use it because i want it to stay new! lol
SO i guess i'll live with the 1 remote being a little funky. Nobody see it anyway but me
Old Feb 25, 2010 | 09:28 AM
OKStateG35's Avatar
Haha, exactly how mine are. I really wish little things like that didn't bother me...but they do.
As far as programming goes, surely there are instructions floating out there somewhere.
Old Feb 25, 2010 | 11:58 AM
Dacket84's Avatar
Here you go, seems easy enough. Looks like you don't have to have the dealer do it which is good...
Quoted from: http://www.infinitihelp.com/diy/comm...am_key_fob.htm
Project: Reprogram Remote Key Fob
Models:
* 2003-2008 FX
* 1999-2002 G20
* 2003-2007 G35
* 1996-2001 I30
* 2002-2004 I35
* 2004-2008 M45
* 1997-2001 Q45
* 1997-2003 QX4
* 2004-2008 QX56
Note: The horn chirp can be disable by pressing the lock and unlock buttons simultaneously until the hazard lights flash, and no enable press the lock and unlock until the horn chirp.
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
NOTE:
Key should be withdrawn from ignition key cylinder completely each time.
NOTE:
Do not rush the insertion/removal key cycling process. The side
marker/tail/license lamps and interior illumination will flash twice when this step is
accurately completed.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Press any button on the new remote controller once. (The hazard warning lamp will then flash)
NOTE:
Do not press the button more than one time in the above step. If the button
is pressed more than one time, the programming procedure will not be successful.
The side marker/tail/license lamps and interior illumination will flash twice when this
step is accurately completed and programming is successful.
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch
(In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
NOTE:
If you need to activate more than two additional new remote controllers, repeat
the procedure on step 5 "Additional ID code entry" for each new remote controller.
NOTE:
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
Old Feb 25, 2010 | 12:36 PM
Ludafish's Avatar
These procedures to program a key fob reminds me of entering cheat codes on the first nintendo
Old Feb 25, 2010 | 12:50 PM
Dacket84's Avatar
This procedure seems more simple than some of the others I've seen... Some are like, turn key to acc and off 3 times, unlock your door, lock it, unlock it, open door, shut it, open window, climb out of window, open trunk, unlock front door to house, kick your cat, shut the trunk, check the mail, press unlock on your FOB, open rear passenger door, close it... you get the idea... lol
Old Feb 25, 2010 | 01:47 PM
OKStateG35's Avatar
So with an i-key can you just buy a new fob and reuse your key? I'm guessing the key and the fob are not tied together by some code, but who knows. I would rather do this than have to get a new key cut.
Old Feb 25, 2010 | 01:51 PM
Dacket84's Avatar
Considering they're selling preowned remotes with new uncut keys on ebay, I'd have to say they're not tied.
Old Feb 25, 2010 | 02:34 PM
Mustang5L5's Avatar
Nope. I've left my key in the house far away and have been able to start and drive the car with the fob part only.
