Need suggestions for a foglight setup on the Kurookie Bumper.
Old Feb 27, 2010 | 11:24 PM
LyricallySick's Avatar
^^ you and Tim said the same thing. Guess I will try to fit small fogs, if not then the hell with it. lol.
Thanks for the opinions so far gentlemen.
Old Feb 28, 2010 | 12:34 AM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by OCG35
I prefer to leave the opening for air flow... as is it directs additional air to radiator (just like OEM does, with the cup/funnel thinig just behind the bumper), or modify it to direct air to the brakes with ducting...
What if you did something like this.....
Originally Posted by dsmmyth
.....only leave the big fog light out for airflow sake. Just do the LED part of the fixture, either on the outside edge or the inside edge.
Old Feb 28, 2010 | 12:51 AM
4drmadness's Avatar
get dual fogs
Old Feb 28, 2010 | 01:34 PM
NjMatteSedan's Avatar
Audi style leds on the upper part of the vents. You're not copyng oudi cuz you're not putting them on the headlights
Old Feb 28, 2010 | 01:36 PM
r1forever80's Avatar
He wouldnt be copying audi but would be coping porshe then
Old Feb 28, 2010 | 01:49 PM
alfhasg35's Avatar
i think the kurookie bumper looks clean the way it is.. no fogs.. do you have a lot of fog in your area..??
Old Feb 28, 2010 | 02:03 PM
^ I'm pretty sure he's doing it for looks not for fog
Old Feb 28, 2010 | 02:15 PM
Mustang5L5's Avatar
Taurus SHO has LED's on the lower bumper now as well
Old Feb 28, 2010 | 09:39 PM
Not fog, but sometimes I could use the extra visibility. There are some communities and areas where there isn't enough light to watch for potholes or broken roads. So, I figured, some fog lights will help.
Old Feb 28, 2010 | 09:40 PM
Originally Posted by 4Dr.Madness.
get dual fogs
The like new Benz. Just sick with it.
Old Feb 28, 2010 | 09:41 PM
If anything, maybe just a projector on the corner behind the grill. If not, then dual projectors in the headlights. The KuRookie bumper looks sick as is.
Thanks for the suggestions again.
Old Feb 28, 2010 | 09:44 PM
Dual projector retrofit is the way to go to get that focused light. i did mine and see the road with no problems when both are on
Old Feb 28, 2010 | 09:49 PM
^ Got any pictures? Which setup? S2000 and TL?
Old Feb 28, 2010 | 09:56 PM
I have s2k for low and fx35 for my drls and hi. A better setup imo would be fxr in upper location for low and hi and some type of single projector for fog in lower location
Attached Thumbnails Need suggestions for a foglight setup on the Kurookie Bumper.-007.jpg
Old Feb 28, 2010 | 10:02 PM
  #30
Nice setup. How much did it run you? Also, your boosted? If so, sick.
