Too Aggressive Wheel Setup??
Old Mar 28, 2010 | 07:07 PM
813G-WHiP's Avatar
Front: 19X9.5 +22
Rear: 19X10.5 +22
05 sedan slammed
Old Mar 28, 2010 | 07:12 PM
shrty10135's Avatar
im really not sure but 9.5 in the front sounds like it will definelty rub when turning and if its slammed your gunna have to either roll fender or do some camber work, i dont know about rear but sounds wide
Old Mar 28, 2010 | 07:24 PM
Invalid_User's Avatar
I have no advice for sedans, sorry.
Hey were you on in Tampa yesterday? I saw a nice sedan slammed and it was IP.
Think it was on Dale mabry around 10pm
Old Mar 28, 2010 | 07:31 PM
FlyingLumpia's Avatar
it should work if you run a 225/35 245/35 you might be able to run a 235/35 245/35 on there.
Old Mar 28, 2010 | 07:34 PM
813G-WHiP's Avatar
yeah i work off euclid and dale mabry and live in brandon
Old Mar 28, 2010 | 07:44 PM
Nice!
Clean sedan
Old Mar 28, 2010 | 07:45 PM
What wheels are you getting?
Old Mar 28, 2010 | 08:28 PM
STCLAIRWEST's Avatar
It should fit with enough camber and stretched tires
Old Mar 28, 2010 | 08:44 PM
813G-WHiP's Avatar
not sure but i keep finding rims i like but they are for coupes.. i found some te37 knock offs that are matte black which i really like.. not the jlb ones.. and then some gt-v knock offs but i cant seem to find a staggered set..
honestly if i had the money id try to get ahold of some bbs super rs's just too see what itd look like..
Old Mar 28, 2010 | 09:12 PM
biggz786786's Avatar
i think these would look sick for an ip sedan
and they are super cheap
Old Mar 28, 2010 | 09:24 PM
SDGenius's Avatar
^they look super cheap
Old Mar 28, 2010 | 09:34 PM
The Stimulation's Avatar
If tires are stretched, there won't be any rubbing issues. I've ran a 20x9.5 +3, slammed, and with 225/35 tires and no rubbing.
Old Mar 29, 2010 | 12:02 AM
4drmadness's Avatar
yes sir
Old Mar 29, 2010 | 10:29 AM
813G-WHiP's Avatar
What about the rears? Is 10.5 to wide? And is this with fenders rolled and pulled?
Old Mar 29, 2010 | 10:52 AM
Fenders will need to be rolled, I'd recommend flat. The guys I've seen run 10.5's in the rear, I'm not sure if they have pulled their fenders, don't think they have. If you do need a pull, it's probably not much of one.
