Rim Setup
Old Mar 29, 2010 | 05:17 PM
Nyteowl's Avatar
Rim Setup
Hi All,
Just want to find out if these specs will fit my 03 sedan.
18x8.5 25 offset and 18x9.5 20 offset..
Old Mar 29, 2010 | 06:35 PM
G SEDAN's Avatar
it will fit, but to what extent are you willing to go to make it happen?
Old Mar 29, 2010 | 06:39 PM
4DGS's Avatar
Stock height? If you're at stock height, yes they will fit with a thin sidewall tire, they'll just look wack.
If you're low you're going to need about -2 degrees of camber and a decent stretch (215/35 rear 195/35 front)
You'll also need your fenders rolled.
Old Mar 29, 2010 | 07:47 PM
Blue Dream's Avatar
I drove ttrank's car solo
Depends what you are looking for out of your setup. If you are looking for flush the coupe 19's specs are just about right on. 19X8 +30 Front and 19X8.5 +33 in the rear.
Outside of that if you want poke and stretch your options are many. Here's my 05 with 245/40/19s all around.
Old Mar 29, 2010 | 11:06 PM
Nyteowl's Avatar
thanks for you replies..
the offsets are too aggressive, so much more problems in the long run anyways..
i'll keep searching..
Old Mar 29, 2010 | 11:53 PM
4DGS's Avatar
Good call
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
