Sedan Specific Coilover Question
Old Apr 1, 2010 | 05:37 PM
XDR-V35's Avatar
I'm getting my BC Racing coilovers and I know with them on a sedan the drop is more so than the coupe. So my question is, to get my allignment back into spec what other components are required? ie. would Rear Camber bars work or do I also need the Front A Arms and Toe Link. Also a second question, has anyone experienced the quality of Ichiba products, it appears to be a Cusco replica and cost a 1/3 of the price. Any other suggestions on specific companies that make "better" or more user friendly products in this field?
Old Apr 1, 2010 | 06:52 PM
Johnnyone's Avatar
From what the vendors on here told me. The coilovers for coupe sedans and zs are all the same. The coupe dropping more only applies to springs and not coilover setup.
As for getting within spec it depends how much your drop is. If only drop like an inch u should b within specs with stock arms.
Not sure of the quality of ichiba but I know they don't come wit a template for the toe bolt which is ok cause the template can b found on here. I have spc rear camber arms and they seem to b good quality.
Hope that helps
Old Apr 1, 2010 | 07:22 PM
Bestswat's Avatar
^+1. It all depends how low you go with the coilovers to determine if you can get back to spec.
Jusseth
Sep 13, 2020 12:25 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
