"Third" Brake Light Out- The One up top inside Car..
Old Apr 2, 2010 | 02:17 PM
numair's Avatar
Just got a 2004 Auto-Sedan with a rear wing which has the (led?) lights on the strip. However, I've noticed that the other "third" light, the one inside the car behind the rear windshield doesn't light up when I press on the brakes. Is this because I have the wing with lights? Can both these light up? I noticed the one inside looks like a LED light, so if it doesn't light up at all, it's probably unlikely that all the bulbs are out, correct? Is it therefore more likely a connection or diode issue?
Have searched the forum but can't find anything about this...
Thanks, I'm pretty much a noob!
Old Apr 2, 2010 | 04:11 PM
5150DS's Avatar
If it came with the wing stock it should not light up and has been disconnected. Even if it was added later they most likely disconnected the 3rd interior light and connected the one on the wing. It would look goofy if both the wing and the 3rd brake light lit up.
Old Apr 2, 2010 | 04:28 PM
numair's Avatar
Thanks!
But is there a way to connect it? Does it really look goofy?
Old Apr 2, 2010 | 05:15 PM
Blue Dream's Avatar
I drove ttrank's car solo
Don't hook it up. It will look silly to have brake lights in your window and your spoiler.
Old Apr 2, 2010 | 06:15 PM
davidxu's Avatar
yes. it will look goofy. If you want to, go ahead, no one can stop you. Open your trunk, and remove the trunk upper lining. You will see the third brake light connection wire.
mike730
Jan 12, 2018 04:25 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Nick_M
Aug 3, 2015 11:08 PM
RedBaronK
Jul 27, 2015 03:19 PM
Lsantana757
Jul 20, 2015 09:08 AM
