Cheapest and easiest way to lower my sedan??? PLZ ADVICE
Apr 14, 2010 | 01:22 AM
  #31
Quote: 1/2" isn't worth it.
get a 350z setup and drop it 1" around. If you have the sport suspension just get the unrevised Z springs and you're set.
This is exactly what I am doing. I'm just waiting for the springs to arrive. We'll see how it goes but later depending on how I like the drop I might look into getting some coupe rear springs to get the G/Z drop.
The idea behind the G/Z drop is to give you a more even wheel gap front to rear. The Z springs will drop you about an inch all around and the coupe spring about a half an inch. The way the sedans naturally sit the wheel gap in the front is bit more then the rear so by going with Z springs in the front and coupes in the rear it should even out the wheel gap. I'm not sure how noticeable the gap differences are so I will see how I like that Z springs all around. The G/Z combo does seem to be quite popular but like someone else mentioned it can be hard to get someone to sell you just fronts or just rears.
I'm pretty new to all this but this is what I have gleaned from chatting with people and digging through the forum.
Reply 0
Apr 14, 2010 | 02:48 AM
  #32
easy and cheap!
Reply 0
Apr 14, 2010 | 06:42 AM
  #33
I'm dropped on sedan H Techs and really like the look and ride. You could probably find a used set for ~ $100, new they run ~ $180
Reply 0
Apr 14, 2010 | 09:17 AM
  #34
Quote: I'm dropped on sedan H Techs and really like the look and ride. You could probably find a used set for ~ $100, new they run ~ $180
Ok. I'm not committed to buying some 350z unrevised springs/struts/shocks for $80......but do you guys think that for another $100, I should buy the Tein H-Techs.....are teins a good ride??
Reply 0
Apr 14, 2010 | 09:47 AM
  #35
don't forget the camber kit
Reply 0
Apr 14, 2010 | 10:11 AM
  #36
Quote: don't forget the camber kit
This is what I have been wondering.. for the sedan, anything lower than the coupe springs requires a camber kit for the rears, right? Or can you put the Z springs on and have the camber be ok?
Reply 0
Apr 14, 2010 | 11:16 AM
  #37
Quote: Ok. I'm not committed to buying some 350z unrevised springs/struts/shocks for $80......but do you guys think that for another $100, I should buy the Tein H-Techs.....are teins a good ride??
From what I've read, the H-Techs are great. If it was me, I would get them over the Z setup. Also, I think several members are running them without a camber kit since the drop is so mild.
Reply 0
Apr 14, 2010 | 11:18 AM
  #38
Quote: This is what I have been wondering.. for the sedan, anything lower than the coupe springs requires a camber kit for the rears, right? Or can you put the Z springs on and have the camber be ok?
I think the general rule is that anything over .5" in the rear starts to benefit from a camber kit. Z springs will drop you 1" so you will have some minor camber issues. Sedan H-Techs drop around .7" I think and some people go without a camber kit. It's really up to you and whether or not you want to avoid excessive tire wear.
Reply 0
Apr 14, 2010 | 11:23 AM
  #39
Quote: I think the general rule is that anything over .5" in the rear starts to benefit from a camber kit. Z springs will drop you 1" so you will have some minor camber issues. Sedan H-Techs drop around .7" I think and some people go without a camber kit. It's really up to you and whether or not you want to avoid excessive tire wear.
Tire wear I might be ok with, but if the tires are majorly tilted, I would not be able to stand it. Plus obviously the camber kits make lowering a car much more expensive..
Reply 0
Apr 14, 2010 | 11:34 AM
  #40
damn i dropped like 2.5 and havent even taken it in for an alighnment
Reply 0
Apr 14, 2010 | 12:04 PM
  #41
Quote: damn i dropped like 2.5 and havent even taken it in for an alighnment
Are the wheels all angled out?
Reply 0
Apr 14, 2010 | 12:18 PM
  #42
the H techs only put you at about -1.3 camber; that's not that bad.
Reply 0
Apr 14, 2010 | 12:29 PM
  #43
Quote: Are the wheels all angled out?
Im dropped all around on a 1 finger gap and havent had an alignment done since november. Theres a lot of negative camber like -3.
Reply 0
Apr 14, 2010 | 12:35 PM
  #44
Quote: Im dropped all around on a 1 finger gap and havent had an alignment done since november. Theres a lot of negative camber like -3.
I'm willing to bet that your toe is off, that is why geww1z was asking if your tires were angled out. You should get an alignment soon so you don't wear through your tires prematurely. Might as well throw on a rear camber kit and add some positive camber (unless you need to run that much camber so you don't rub).
Reply 0
Apr 14, 2010 | 01:25 PM
  #45
im in that situation right now i need negative camber so i dont rub i dropped the car 2 days ago and havent done an alignment yet and did like 80 mph let go of the wheel ans surprisingly went straight as can be like i never did a drop .. and no vibrations are anything im kinda shocked lol
Reply 0
