Cheapest and easiest way to lower my sedan??? PLZ ADVICE
Old Apr 14, 2010 | 01:38 PM
  #46
OKStateG35's Avatar
Originally Posted by nazc0
damn i dropped like 2.5 and havent even taken it in for an alighnment
On Sedan H-Techs? I thought they were only supposed to drop a RWD 1.4" up front and .7" in the rear.
Old Apr 14, 2010 | 01:42 PM
  #47
OKStateG35's Avatar
Originally Posted by geew1z
Tire wear I might be ok with, but if the tires are majorly tilted, I would not be able to stand it. Plus obviously the camber kits make lowering a car much more expensive..
I think I've read these cars come with a slight negative camber from the factory so any drop will just exaggerate that. I would PM Blue Dream and ask him about his setup. He has a RWD with Sedan H-Techs, but I'm not sure whether or not he has a camber kit.
Old Apr 14, 2010 | 01:44 PM
  #48
SN00P's Avatar
CLUB MODERATOR
^^ that is correct 1.4'' front and .7 rear
im on 350z tein s techs and im 2.5''
Old Apr 14, 2010 | 04:02 PM
  #49
imclumzy's Avatar
For those with the 350z struts and 350z front / G35 Coupe rears, can you comment on the ride quality? Does it feel the same as the sedan non-sport suspension or harder / firmer? Does it crash over bumps more?
Old Apr 14, 2010 | 05:16 PM
  #50
NFSP G35's Avatar
? = 2B || !2B
I have revised 350z struts/shocks/springs all-round.
The ride isn't bad at all. Yes it's firmer than the non-sport, but it doesn't jar your teeth at all, and I live on a bumpy road. Just makes the car feel more like a sports sedan should (IMO)
Also, not 'bouncy' at all, which is a very good thing. I don't really mind a slightly hard bump, if that's all there is, but I hate when a car is cushy, but then bounces after the bump.
Old Apr 14, 2010 | 05:49 PM
  #51
G SEDAN's Avatar
just give rides to a bunch of fat friends
Old Apr 14, 2010 | 06:41 PM
  #52
nazc0's Avatar
2006 Vortech supercharged Sedan
Originally Posted by g35snoop
im in that situation right now i need negative camber so i dont rub i dropped the car 2 days ago and havent done an alignment yet and did like 80 mph let go of the wheel ans surprisingly went straight as can be like i never did a drop .. and no vibrations are anything im kinda shocked lol
same here i thought i was done lol
is have s-techs and my wheels look straight to me
Old Apr 14, 2010 | 08:38 PM
  #53
SILVERAZG35's Avatar
If I get the Tein H-tech springs, do I need anything else, besides a possible camber kit???
Old Apr 15, 2010 | 12:42 PM
  #54
imclumzy's Avatar
Thanks for the mini-review NFSP, I think I'm gonna go 350z / G coupe and 350z struts. The price and performance seems to be right.
How's your camber all around?
Old Apr 15, 2010 | 03:28 PM
  #55
Bestswat's Avatar
correct candlestick, toe is off too. Idk any other way to tell but if your car starts fishtailing randomly in the rain while going straight, toe is off.
I'm willing to bet that your toe is off, that is why geww1z was asking if your tires were angled out. You should get an alignment soon so you don't wear through your tires prematurely. Might as well throw on a rear camber kit and add some positive camber (unless you need to run that much camber so you don't rub).
Old Apr 16, 2010 | 12:08 AM
  #56
NFSP G35's Avatar
? = 2B || !2B
Good'nuf.
I don't know really. They told me it was just barely outside stock specs. One guy said it will actually go into stock spec for the 350Z which is slightly more aggressive than the sedan.
Here's a link to those specs: https://g35driver.com/forums/5027161-post289.html
Old Apr 16, 2010 | 07:47 AM
  #57
SN00P's Avatar
CLUB MODERATOR
^^^ thanks for that info those will be the specs im going to be using
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
ghost_g35
Aug 7, 2015 10:31 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
hippiGlass
Engine - Exhaust
Jul 16, 2015 07:48 PM
