2005 6MT Sedan Redline
Old Sep 20, 2004 | 12:18 PM
McG35's Avatar
The redline for 6MT 2005 G35 has been raised to 7000rpm!!!
Check it out:
http://www.nissannews.com/
go to Infiniti, then 2005 G35 Sport sedan, and click on Specs.
Old Sep 20, 2004 | 04:30 PM
BrianV's Avatar
Re: 2005 6MT Sedan Redline
Interestingly:
Horsepower
AT: 280 hp @ 6,200 rpm
MT: 298 hp @ 6,400 rpm
Torque
AT: 270 lb-ft @ 4,800 rpm
MT: 260 lb-ft @ 4,800 rpm
It sounds like they put in higher lift cams to raise HP. Of course a new ECU will also be required. Based on the pictures, I think the exhaust will be the same. Thus, for upgrades for 03, I think we're out of luck as replacing cams and ECU will be costly.
This was a VERY interesting find, the lower torque figure on the 6MT. Here's the URL:
http://www.nissannews.com/infiniti/2...an/specs.shtml
04 6MT Sedan - Z Tube, K&N Drop-In, 04 Z Suspension
Old Sep 20, 2004 | 06:16 PM
dklau33's Avatar
So it sounds like the 6MT's are getting variable valve timing on the exhaust side as well and thus the uprated HP figures. It'll be interesting to see some stock dynos on these 05 models.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs
tiguy99
Mar 1, 2016 11:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
