eibach sway bar CREEKS and NOISES HELP!!
Old Apr 27, 2010 | 01:08 AM
Black Rain's Avatar
1. when turning my steering wheel up my curb into my drive way it sounds awful! from the front, left and right. both when my front wheels go up and back noise comes from front under area.
2.when going fast/slow/any speed over DIPS it creeks/clunks awfully in the front.
3. also, not sure if this is from it or not but just noticed it, i think it could be with my brakes somehow, a metal on metal clinking on my right front area.. ideas?
thanks a lot guys. just recently got new eibach sways and springs that dropped it 1.1inches.
Old Apr 27, 2010 | 02:00 AM
ZE120's Avatar
i had a simillar problem. when my front right wheel turned, the caliper was scraping the rotor in certain spots. it made noise with every revolution.
turned out the wheel bearing was deformed causing unbalanced scrappage.. not sure if you have the same problem. just my two cents .
good luck!
Old Apr 27, 2010 | 02:04 AM
4drmadness's Avatar
buy aftermarket endlinks
Old Apr 27, 2010 | 02:12 AM
SCIONMIKE's Avatar
oil it up?
Old Apr 28, 2010 | 10:06 PM
Black Rain's Avatar
just oiled the bushings.. not sure if that is what the end link is or not?
Old Apr 28, 2010 | 10:13 PM
5150DS's Avatar
Might be the compression rod bushings also.
Old Apr 29, 2010 | 03:31 PM
Black Rain's Avatar
doesnt matter anymore. blew my tranny. i believe it is time to go back to stock and sell the car. so much to do..
Old Apr 29, 2010 | 03:57 PM
STCLAIRWEST's Avatar
That sucks man good luck with the part out
Old Apr 29, 2010 | 04:01 PM
Black Rain's Avatar
really does. i think imma try for the newer g37s. not sure if ill stick with the sedan or go coupe. will have to look into some specs on which is faster/lighter and **** like that
Old Apr 29, 2010 | 10:04 PM
DivZero's Avatar
the coupe looks hawwwt!!!! the sedan looks like Ellie
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
