I need help: suspension!
Old May 9, 2010 | 04:47 AM
bound4VIP's Avatar
Originally Posted by LuXXXz
so the outer tie rod?
the tie rod its self, it is connected to the rack and pinion it is covered by a boot. the bearing should not be able to move by your hands, that is if you completly removed it. If you can, it is bad and will cause it to wiggle left and right.
Old May 9, 2010 | 09:36 AM
LuXXXz's Avatar
ill check it tomorro. im gonna take the wheel of. the thing is it was way diffferent when one side is up and when both sides (front) is up in the air! cause when i got my tires they had both sides up. and at home it was alot tighter when only the drivers side was jacked up
Old May 9, 2010 | 11:40 AM
DaveB's Avatar
When did this sound start occuring? Was it right after installing something on the car?
Why not just take to a shop tomorrow? The issue could a whole slew of things, but I highly doubt it's a rotor or wheel bearing. My guess is it's upper control arm or something in the lower control arm assembly. I'd jack the entire front end of the car up and remove both wheels and start inspecting the driver's side and compare anything odd to the passenger side just as a check/balance. I'd use a small pry bar or large screwdriver to move things around.
Seriously though, it's only a car. It's nothing to get worried or upset about. As cars get older, things start to wear, especially suspension. You can't expect everything to last forever. The issue is likely a relatively easy fix.
Old May 9, 2010 | 03:20 PM
LuXXXz's Avatar
the noise kept gettin worse over time, i had horrible alignment for the winter and it was messing up my tires and also my shocks were bad so i changed them to coupe ones as well as changed my brakes too. it was happening before that.
why are the vdc slip light on turn on after like 10 minutes of driving??
could it be about the alignment
Old May 9, 2010 | 06:30 PM
bound4VIP's Avatar
as far as the VDC light, check your brake fluid.
Old May 9, 2010 | 10:23 PM
LuXXXz's Avatar
brake fluid is fine. the slip vdc light doesnt go on till like 10-15mins after driving!
and if its brake fluid doesnt the brake light go on also?
Old May 9, 2010 | 10:27 PM
LuXXXz's Avatar
i was doin searches on the vdc slip light and somepeole were saying it could be w/ the steering since it works for the vdc calibration so probably because of the alignment need its on
Old May 10, 2010 | 01:17 AM
DaveB's Avatar
Are your tires the same size?
Old May 10, 2010 | 03:16 PM
LuXXXz's Avatar
they were before 225 50 17
and now the front ones are 215 55 17 since thursday and the back ones wil be chaned to 215 55 17 next week, but this was happening way before these tires i got this past weekend.
Ok guys went to get an alignment done and they did a free survey for me and said it was the bottom tie rod and and also the inner end too, but i dont think it was the inner once since its fine when turning so im ordering the outer tie rod tomorrow 30 bucks and he couldnt find the problem at first cause he had only one side picked up at frist and once he had both sides of the G in the air it was a different story, you can tell under the car so easy there was play on the tire rod ball joing
and hopefully will solve the problem get an alignment and will be happy w/ the G35 once again! i love my car still but its just so frusturating when you can figure it out.!
Old May 10, 2010 | 03:46 PM
bound4VIP's Avatar
I hope it is just cost $30 to fix your problem, my "inner ends" for my eclipse ( yes i have an eclipse, dont judge me. lol its clean and not riced out) was $250for parts.
Old May 10, 2010 | 11:30 PM
LuXXXz's Avatar
i found tire rod ends on rockauto for 20 bucks
and i have a question are the sedan coupe and 350z tire rods the same part number
anyone know?
Old May 11, 2010 | 02:47 PM
LuXXXz's Avatar
guys where can i get tie rod ends??
and i have a question!
are the coupe, or 350z tire rods the same part number?
Old Jun 5, 2010 | 12:22 AM
EqualG's Avatar
Did you check the lower control arm? Had a similar issue and replaced the bushings on my lower control arm (inner) and all is good.
Old Jun 5, 2010 | 12:30 AM
LuXXXz's Avatar
fixd my problem tire rod ends were fine
the wheel hub was Fd up and then the bushin on the control arm! so check those
i changed em even though i got a used wheel hub wow what a difference drives like new
Old Jun 5, 2010 | 12:46 PM
  #30
GAU-8's Avatar
Wasn't that mentioned in the beginning? I thought the bearing was part of the hub?
