Where can i get a Bigger Rotor kit??
Old May 13, 2010 | 05:22 PM
C63someday's Avatar
Hi there, Just like the title says where can i get a big rotor kit? No caliper just bigger rotors with a caliper relocation bracket? On my nissan slivia I upgraded to z32 brakes and wanted bigger rotors so i got the AMS big rotor kit and it came with brackets to relocate the calipers for the 2'' bigger rotor, Is there something like this for the G sedan?
And i know i wont stop better, i dont wanna drop 1/4 the Value of my car into a BBK, Just want a better look.
Old May 13, 2010 | 05:26 PM
Jeff92se's Avatar
Red Card Crew
Racing Brake
Or if you want something even more oem, I went with a set of 06 Z front/rear calipers/rotors.
Or if you want a little oem bling, a set of OEM brembos. front/rear calipers/rotors.
Old May 14, 2010 | 12:04 AM
BuckeyeInMI's Avatar
Smart move. Jeff is right, the Racing Brake OEM upgrade and the 05+ OEM upgrade are pretty much the only things out there that will give you a bigger rotor without breaking the bank. 05+ will cost around $400 or so, give or take (search the Marketplace), depending on what you put into it (SS lines, caliper rebuilds, etc.). The fronts are 12.6" and the rears are 12.1", about 1" bigger on both over the 03-04 rotors. The RB upgrade is around $1250 for both front and rear, giving you 13" rotors on both. You can upgrade it later by adding a 4-piston front caliper for another $650-ish. No upgrade on the rear, however.
The next best option is going with the Akebono setup for as little as $1650, which will give you new calipers (2-piston front, single rear) and new rotors (14" F & R). https://g35driver.com/forums/brakes-...-06-sedan.html. But the Akebono setup won't fit under a 17" wheel.
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
Machine Head
Sep 4, 2015 07:22 PM
mikemf8
Sep 3, 2015 08:01 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
